Going Procharger...
I buy everything procharger related from Bob. Best service at the best price. 1000 rwhp with the 416 will be a nice combo easy to drive and maintain for a streetable combo. I make roughly 1000 rwhp through an auto on my little 377 with 241 heads...yes you heard that right 241 heads with a BTR .660 spring kit in them and BTR equalizer manifold.
Cubic inches and expensive heads aren't needed with a procharger, but they certainly help giving you more torque throughout the range and making the peak power number at a lower boost number. I use e85 and meth injection on at 4 psi I've found heat not to be a problem at all with the blower spinning 75,000 RPM. (8.25 crank pulley, 4.12 blower pulley, shifting at 7000 RPM).
For your combo stock LS3 heads on the 416 would make 1000 rwhp easily with the F1a-94 spinning the blower 73,000 to 75,000 rpm and probably be around 15 psi of boost. That same blower speed makes about 20 psi peak boost on my little stock headed 377.
A more efficient combo (better heads, intake, etc) will likely not make much more peak power with the same procharger at the same impeller speed when we are talking about an F1a-94 at the 1000 rwhp level not trying to squeeze everything out of it.
For example, if I spent $3500 on a set of heads to replace my 241's I'd likely gain a little power maybe (50 rwhp) and my boost would drop a couple psi. More power with less boost while still running the same pulley's on the crank/blower (same impeller speed).
For me at the time I put the combo together $3500 was a lot to spend when my goal was only 750 with the D1x I started with. I could just run a couple more psi right? To an extent yes and then just slap an F1a-94 on it later when I wanted more. The head unit cost me less than a set of heads after I sold the D1x. The F1a-94 over the D1x definitely gave me more than the heads would for the money right?
I definitely am at the point I want better heads now, but thinking I may wait until I build the next motor and may want an F1x by then...lol.
My opinion isn't popular, but I don't like putting a ton of money in a motor if I can run a bigger blower and make more power with more boost on a cheaper engine because engines don't last forever. If you are class racing and limited by blower size, then absolutely you need the most efficient engine combo possible to get everything out of that blower limitation.
ATI ProCharger and Moser Sales 260 672-2076
PM's disabled, please e-mail me
E-mail: brutespeed@gmail.comob@brutespeed.com
https://brutespeed.com/ Link to website
In my case, for my sons car, it might be one night in a month doing small 60-130 pulls across Gandy Bridge.
Oh and BTW, it's stick car
The low mount Procharger whether manual adjustment or their new HD tensioner bracket is less than ideal (I own one so I know). One advantage is the Procharger belt is dedicated and short. Air intake tube and air filter location is not great being under the front fender in front of the wheel.
I sell these kits for less than what is shown in the link, call me for pricing.
I may have missed it, but can you keep functional AC with your Corvette based kits in 4th gen Camaro?
98-02 F Body ProCharger Systems
