Corsa sport cfm rating?
Old Mar 24, 2024 | 10:31 AM
sewerpickle's Avatar
Default Corsa sport cfm rating?
How many cfm will a corsa sport muffler flow? I'm building a 1953 belair with a 5.3, mild cam, vortech v1 s trim. A single muffler will be much easier for space requirements but unsure if a single muffler will flow enough.
Old Mar 24, 2024 | 10:56 AM
Ls1Rx-7's Avatar
You’ll likely have to ask the company directly and im sure there is some difference in flow between their different models that are 2.5” and 3”.
Have you considered a boost activated cutout installed before a quiet oem style muffler which will give you the best of both worlds? You could even install the corsa before the cutout so its still tame when it opens.
Old Mar 24, 2024 | 01:56 PM
Yea, I was planning on contacting Corsa about this question. I'm not going to dive in to doing boost activated cutout or anything fancying. This is just a street car with some blower whine, I'm still debating on whether or not to use corsa mufflers. I love the LS platform but find it hard to make them sound good, in my opinion.
Old Mar 25, 2024 | 04:07 PM
Forcefed86's Avatar
The carven R mufflers are a straight through design with a similar raspy growl the corsa has. Also much cheaper and compact. About 100 shipped each. I ordered a set to put on a little 13:1 5.3. Should arrive any day now.
Old Mar 26, 2024 | 09:25 AM
Black_Sunshine_99's Avatar
I did a single 3" Magnaflow (largest one that would fit for both noise and flow) on my last 4th gen in the factory location and it sounded good, still had a good tone and noise level, DD ideal.
It got a little louder as it broke in as well but seemed to stop after about a year.
Old Mar 28, 2024 | 09:05 PM
Carven R mufflers are on my watchlist as well. Just hard to tell how they sound on the YouTube. They either sound great, or terrible.
Old Apr 2, 2024 | 09:10 AM
Forcefed86's Avatar
Carvens are weird. I have a set I've yet to use. But they are basically a hollow shell with a small disc inside full of holes. I *think* resonance is the reason they sound cool in some setups and not others. *if* your setup hits the right frequency to get the disc in the shell resonating, It makes a raspy cool corsa like sound. If you don’t, you basically have a straight pipe as they do diddly for sound deadening. I’m a huge fan of the corsa sound as well. The carven setup I heard locally sounded very similar at higher RPM. It was a 2.5” kit with an x pipe and 2 carven R’s on an LS1.
Old Apr 3, 2024 | 05:46 PM
I ended up ordering a dual in/out spintech pro street 9000. After taking measurements there was almost zero chance of fitting two mufflers and have both exhaust pipes coming out the same side. Spintech always seems to sound good even with a mild cam.
