Max rpm built 5.3?
When I overspun my car by accident, I did actually feel it nose over a little bit.
What intake manifold are you running?
you might not have read the whole build. I ditched the stock pump and put a hv/hp melting pump in it. Main studs. H beam rods. Bigger ferrea valves. I have a hybrid turbo with a 1.25 exhaust housing and 4” outlet. I don’t need/want a bigger turbo. This isn’t a drag car and I like the response it has now. I don’t want a 525 as the primary, that’s too much flow, heat, amperage draw for doing what I do with the car mainly…,drive it and get caught in bumper to bumper traffic (like I’m in right now, in the car).
It was a beautiful day to day so I went ran some errands And rode around for a little while. Also just realized that it didn’t lean out after driving and being in traffic. My guess is the fuel was getting over heated from larger 340 pump over pumping at idle and cruise. Just my guess.
so I made some hits while out and about and it was rich so I flashed it a couple times and leaned it out little by little. Still running in the mid to high 10’s but better than low 10’s high 9’s. Seems to be picking up power as I lean it out. On the way home I made a couple first gear to second gear hits and tried to pull it higher. It nosed over before the 7500 limiter. I noticed I was only getting 12psi vs the normal 14 so I turned it up two levels. Boosted still down. I thought to myself, why would I be losing boost as I go leaner? Then I was thinking the duty cycle option on my boost controller might be the culprit. Then I realized when I got home, I had closed the exhaust when I went through the Zaxby’s drive through and never opened it back up. Doh. It seems to choke it and lower the boost a couple to a few psi depending on how high I have it turned up. O well. I’ll make some more hits with it open and post back.
