Max rpm built 5.3?
Old Mar 24, 2024 | 12:29 PM
Kfxguy's Avatar
Default Max rpm built 5.3?
What kind of rpm would still be safe to turn? Aluminum block 5.3, arp main studs, summit h beam rods and forged pistons, stock crank. 222/233 cam. I’m shifting around 7000 currently but I think it’ll probably go at least 7500. I can dial in more boost up top to compensate for lack of camshaft. Why? I like rpm’s and the sound of it. Plus it may go faster. My trans might not like it tho.
Old Mar 24, 2024 | 01:28 PM
LS1Formulation's Avatar
I'd be more concerned with the valvetrain at those kind of RPMs. I think the 5.3 bottom end you have would spin to 8K+ without issue.
Old Mar 24, 2024 | 02:20 PM
Kfxguy's Avatar
well I tried to figure out what springs I have. Unfortunately Brian Tooleys website is a dumpster fire basket case when trying to find something so I had no luck there. I went grabbed the spring kit box to get the part number, well they use cheap *** tags on the box so the print has disappeared. The only thing I remember is they were for the bigger btr 228/232 cam I used to have in there. Double spring and titanium retainers, .650 lift iirc. So in essence, it’s probably a little over springed. The lifters are Johnson typify (I think). Been a while since I built the engine.
Old Mar 24, 2024 | 03:40 PM
I don't know if it's over sprung for the RPM, especially considering that boost will actually drop your seat pressures by around a factor of 3 ( if you have a 2.00 valve, it's around 3 square inches of area, accounting for the stem ). If you run 15 PSI of boost, you're effectively dropping seat pressure by around 45 lbs. This can, at high RPM, cause valve bounce off the seat. This is why I went with BTR platinum springs with Ti retainers, and shimmed them to around 1.765" in order to compensate for the pressure loss under boost. You can also get into spring surge at times, so you may want to play around with shimming them to within .050-.060" of coil bind if you're really serious about frequent trips to 7500+.
Old Mar 24, 2024 | 05:08 PM
Kfxguy's Avatar
if I had to guess, I have the platinum springs too, and I do have ti retainers. I might shim them a little more especially since I have less lift now.
Old Mar 24, 2024 | 05:43 PM
TrendSetter's Avatar
all the sbe record guys are spinning 88+
dont be a *****, send it
Old Mar 24, 2024 | 07:20 PM
Ls1Rx-7's Avatar
always take any advice that includes “dont be a *****” in it!
That being said you definitely want a solid valvetrain and possibly a solid roller setup if you want to turn over 8,000 rpm reliably.
Old Mar 24, 2024 | 07:25 PM
Kfxguy's Avatar
7800 would be fine at this point with this motor. I’m currently doing some different fuel pumps in it but when it’s back running I’ll turn it up some more.
Old Mar 24, 2024 | 08:45 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I shift my SBE LM7 (230/236 Baker/Capizzi) cam at 7800, 8500 by accident once.
The forged LC9 I'm building will continue that.
Old Mar 25, 2024 | 07:01 AM
ive got the elgin 1840 in mine and it clearly drops off at 6000 unfortuantely. i spun it up to like 72-73 on the dyno hoping for an excuse to always spin it up like that.
Old Mar 25, 2024 | 09:23 AM
Kfxguy's Avatar
that’s odd. My cam, which has less duration, pulls cleanly to 7000 rev limiter.
Old Mar 25, 2024 | 09:31 AM
it pulls clean, but power peaks at 6k. i have a mainline dyno so its a little bit of extra data to see whats going on.
Old Mar 25, 2024 | 12:54 PM
Black_Sunshine_99's Avatar
Spin it up son!
I shift my rod/piston LS1 at 7,000rpm so by the time everything takes place its around 7,500rpm.
BTR .660 drop in springs and Brute Speed FI cam which Bob says should make peak power at 6,800rpm.
I kinda disagree because my car feels good shifting all the way up to 7,500rpm.
If 8,000rpm shift points were my goal then I'd be copying @Pro Stock John combo with the Baker cam, lifters and springs because the cam will ultimately determine valvetrain performance and life span.
Old Mar 25, 2024 | 04:03 PM
Forcefed86's Avatar
I'm pretty sure this has been proven false... Hell I'm pretty sure my early combo proved it false.
The dynamics of the intake port are not static. You need to think in an actual operating condition. The other side of the valve also has a lot of "stuff" going on. In my experience, boost will have "minimal" effect on the spring pressure.
As an example I had a 1218 spring on my combo I was pushing pretty hard with a small wheel T4 in the early days. I saw 2.8:1 back pressure @ 26lbs. Thats 72.8 psi of back pressure... My combo pulled clean to 7k easily. Going by your math I'd be dropping 90ish psi off a spring that only has 130 psi seat pressure. I'd have all kinds of issues if what you say is true.
Not saying it doesn't have any effect... but its negligible in most cases.
Fwiw I've run the BTR platinum .660 dual spring kit to 7800ish with an untouched 5.3 valvetrain (aside from push rods and springs) That's original lifters/rockers with no trunnions etc. Also done the same with summits drop in lifter. Which I can only assume is offshore. the SBE record holder guys buzz to 8400 with that same spring kit at 40-45+lbs. Which again I'd think would be impossible if the above mentioned theory was correct.
I'll say longevity is likely greatly reduced... but so far so good.
Old Mar 25, 2024 | 04:57 PM
ls3fox's Avatar
7 Second Club
Btr stage 3 cam sbe 5.3 btr 660 springs made power to 8200 shifted it closer to 8400​​. The heads lifters and springs had close to 20k miles on them
Old Mar 25, 2024 | 05:38 PM
RonSSNova's Avatar
My car goes no faster or quicker shifting at 7400 than it does shifting at 7000. My TH400 has no lag so it shifts when I move the lever.
I would think more cam with better springs etc would make a difference.
Ron
LS1Tech Co-Founder
^Your combo was killer, where do you race, at Cecil?
Old Mar 25, 2024 | 08:49 PM
Ron
To go faster than 8's?
Why mess with a solid combination for a few tenths and spoil it?
Old Mar 26, 2024 | 12:31 AM
Kfxguy's Avatar
Thanks for the replies fellas. Makes me feel better about what I’m wanting to do. Almost done with the pumps install.
Old Mar 26, 2024 | 09:14 AM
Forcefed86's Avatar
I had the exact opposite experience. Each time I went with a taller gear and revved the combo out more, I picked up more et/trap. Started out long ago in 2012 with a 212/212 @ 112 baby cam and 3.00 gears on a 30” tire revving it out to 6500ish. (my very first poorly setup combo I spec'd myself after racing low RPM turbo Buicks )
Many progressively higher RPM combos later… I ended up with a 226/230 @ 113+4, a 3.70 gear, and a 28” tire. Winding out and 7500 rpm. That cam wouldn’t pull beyond 7500. Later combos I target 7800ish with a larger cam. Was a glide though… felt like extending the shift point really helped with a 2 speed. I'd gained a solid 2+ mph in the 1/8th shifting at 7800 vs 7000 in my latest setup.
