Turbo Pressure Gauge MAP/EMAP
I painted one of the TWO pointers, one on top of the other, Red and the other Blue.
The Red pointer was used to measure EMAP and the Blue to measure MAP.
Lance
When the Turbo engine is in "crossover" it will make great power with little chance of engine damage.
What is YOUR record amount?
What would you expect the eMAP RATIO to do as boost activated cut-out OPENED ?
Say your 'test' engine/compressor combo is limited at 12 PSI manifold through 2.75" single pipe and stock factory muffler, than introduce a Y-pipe, and 3" cutout begins open 6PSI, full open by 9PSI
How does shape of eMAP graph change ? steeper or FLATTER ?
