fender exit/ overflow tank
Old Apr 18, 2017 | 12:44 PM
GT Griller's Avatar
Default fender exit/ overflow tank
Those of you guys who run passenger side fender exits. What did you do about the coolant overflow tank? Were you able to run around it or was it relocated. If you relocated it, where did you put it and what tank was used? Pics would be great!
Old Apr 18, 2017 | 12:55 PM
MM98's Avatar
I removed the stock one & bought a cheap overflow from oreillys for like $10. Mounted it between the core support & headlight on the driver side. Not the best pic, but gives you an idea. Been working fine for almost two years now.
Attached Thumbnails fender exit/ overflow tank-img_1296.png
Old Apr 18, 2017 | 12:57 PM
2000WS6TA's Avatar
Literally just had the same issue. Huron speed recommended I put and aftermarket overflow in the trunk. i ended up just finding a small one and mounted it on my radiator shroud. Not the best place for it and im probably going to move it just need to find some space.
Old Apr 18, 2017 | 01:08 PM
GT Griller's Avatar
Sweet deal mm98...i never thought about going behind the headlight with one of them small oreillys tanks. Thank you!
2000WS6TA looks like we are working on a very similar set up according to ur sig..lol
Old Apr 18, 2017 | 01:10 PM
MY_2K_Z's Avatar
I just moved it to the other side.
Old Apr 18, 2017 | 02:34 PM
Gotit4cheap16's Avatar
I deleted mine and cut the battery holder off and seperate it from the overflow and bought these from jegs as replacement.
Attached Thumbnails fender exit/ overflow tank-screenshot_20170418-153221.jpg
Old Apr 19, 2017 | 11:24 AM
2000WS6TA's Avatar
Yea man, it seems to be working well. I put down 566hp on 8lbs and only 8* of timing before i ran out of fuel. I finally have all the fuel upgrades i need and should be hitting the dyno again soon. I'm trying to see where 16psi puts me.
Old Apr 19, 2017 | 08:00 PM
GT Griller's Avatar
What was ur fuel set up at the time?
Old Apr 20, 2017 | 11:20 AM
2000WS6TA's Avatar
340lph pump. stock lines. ls3 65lb injectors. non return style set up.
Old Jul 14, 2024 | 02:07 PM
JoshuaGrooms83's Avatar
Attachment 586473
how did you manage that? That looks good! How are you routing your cold pipe for the turbo?
Old Jul 14, 2024 | 03:19 PM
ScottStaypuff's Avatar
Pretty much my plan but I bought this little guy. I'm hoping to mount on the battery or battery tray.
