Dart 402 block, 10.5 compression, Tooley Trick Flow cnc heads, F1a blower..
Old 06-05-2024, 07:29 PM
stage274's Avatar
Default Dart 402 block, 10.5 compression, Tooley Trick Flow cnc heads, F1a blower..
My new set up; can’t wait for the dyno numbers!
New Dart 402 block, 10.5 compression, Tooley Trick Flow cnc heads, F1a blower, max effort. E-85. .650 inch lift blower cam.
I am using my custom stand off stud I made with a double idler pulley for the blower set up.
Standard 4 inch pro-charger coolers with custom piping.
Fit perfect!
Dana 60 rear end, with 18 inch vette magnesium rims, along with Brembo V brakes up front.
I am excited to see the dyno numbers!
The following 5 users liked this post by stage274:
ALL ULL C (06-07-2024), C5_Pete (06-07-2024), forcd ind (06-09-2024), jayyyw (06-05-2024), Pro Stock John (06-05-2024)
Old 06-07-2024, 01:55 PM
The BallSS's Avatar
Should make about 500whp.....
The following users liked this post:
Jimbo1367 (08-17-2024)
The BallSS's Avatar
Per wheel lol.
stage274 (06-09-2024)
Old 06-07-2024, 08:52 PM
SKEETS64IMPALA's Avatar
I read the description and was expecting a full on race car build, only to scroll down and see a ridiculously clean collector's trans am. Not disappointed.
The following 2 users liked this post by SKEETS64IMPALA:
Jimbo1367 (08-17-2024), stage274 (06-09-2024)
Old 06-08-2024, 02:50 AM
FrankieD's Avatar
Will the Standard 4 inch procharger intercoolers be the Limiting Factor?
Old 06-08-2024, 05:59 AM
BCNUL8R's Avatar
My guess would be the f1a and small intercoolers will be the limiting factor. This combo needs an F1x with the larger race intercooler.
Old 06-08-2024, 09:01 PM
f8lvenom's Avatar
Sweet build. Looks like a street car in which a F1A-94 would be perfect in my opinion.
Old 06-09-2024, 05:06 PM
stage274's Avatar
Yeah it’s a street car. 6 speed. 17k original miles.
Will dyno next week. Let’s see what we pull.
I did not want to cut the front bumper for a front mount.
It’s a sleeper, has stock rear exhaust with an electronic dump.
The custom pipes are killer though! I am happy with the work.
The blower is left over from the old motor I blew.
I know I would pick up much more power with the 94 F1A.
I am curious what we will put down. I will post when the results come back.
The following 2 users liked this post by stage274:
f8lvenom (06-09-2024), forcd ind (06-09-2024)
Old 06-09-2024, 05:27 PM
stage274's Avatar
Maybe. However the cross sectional area of the tubes is larger with the dual pipe system.
We have 4 inch tubes on the bottom, and 3 inch tubes going to the top of the motor.
The coolers are as big as a race front mount only cut in half.
I did not want to cut the front bumper on this 17k mile car.
The only thing is, it needs more blower I believe.
This blower has less than 500 miles on it, before I smoked the last motor.
ALL ULL C (06-11-2024), The BallSS (06-10-2024)
Old 06-10-2024, 09:32 AM
The BallSS's Avatar
There's always an air to water setup you could run, they work really well on the street.
stage274 (06-13-2024)
Old 06-10-2024, 12:18 PM
BCNUL8R's Avatar
air to water doesn’t seem convenient for a street car. Link?
Old 06-10-2024, 12:23 PM
The BallSS's Avatar
No link, my current car uses one and I street drive it all the time, works amazing even with ambient temp water.
Old 06-10-2024, 04:24 PM
BCNUL8R's Avatar
Interesting. I'm at 10.6 to 1 static compression with 20 psi of boost from an F1a-94 on ethanol and meth injection my IAT barely gets above ambient with a large air to air even without the meth, but I still love the meth injection. Having an air to water intercooler in a daily driver just seems like more problems to deal with.
Old 06-11-2024, 12:33 PM
The BallSS's Avatar
It wouldn't have been my choice either, the car came with it, and it works well so I figured why mess with it.
I haven't tried ice water yet, but I'd imagine that's where it will shine over an A2A setup.
On pump gas my IAT's are usually right around ambient +/- 5-10 degrees with the pump off, with the pump on they are at ambient consistently, even making multiple hits.
The temp will go up a little during the run and then come right back down as soon as I lift.
Old 06-11-2024, 05:09 PM
BCNUL8R's Avatar
My IAT runs at ambient playing on the street doing part throttle pulls and kicking her sideways here and there. The IAT actually goes down during wot pulls, but this could be misleading since I'm spraying meth injection 8" or so before the sensor. After a pull it still stays below ambient for a while unless I stop and sit for a while idling then it will slowly creep up. ECT runs at 180 degrees in all conditions. 19 degrees timing peak with 10.6 static compression and 20 psi of boost and plugs show it could take more, but I don't want to push it. Air to air just seems better for a daily driver, but I agree if it was already there, and works might as well stick with it.
I'm really surprised more people don't use meth injection with e85. I know it's not needed, but I've been really happy using it and with e85 if you don't tune to the ragged edge if the meth failed it wouldn't be catastrophic.
The following 2 users liked this post by BCNUL8R:
stage274 (06-13-2024), The BallSS (06-12-2024)
Old 06-13-2024, 08:52 AM
stage274's Avatar
Maybe I should do meth injection? Who has the best kit?
Old 06-13-2024, 09:31 AM
The BallSS's Avatar
I'm getting ever closer to pulling the trigger on an Alky Controls meth kit, Julio recommends his truck kit but I want to upgrade the rear sway bar first.
I know guys make their own or buy $300 kits but I wanna lean on this one and try and get my boost into the 20+lb. range on pump gas.
stage274 (06-14-2024)
Old 06-13-2024, 04:27 PM
BCNUL8R's Avatar
I didn't use a kit. I like stewart warner pressure switches with dual high-quality relays. I use a check valve and single nozzle with a simple on/off no progressive controller. I use a 7gph nozzle all in at 4 psi of boost. No issues at all going all in at low boost. If you use windshield washer fluid or some of the 50/50 premix which likely aren't actually 50% then you might have issues going all in at that low of boost.
Honestly if I could only choose one or the other E85 or pump with meth injection I'd go E85 every time because it is superior, but using meth injection plus e85 is amazing.
Old 06-14-2024, 06:49 PM
stage274's Avatar
Yeah to use meth on E85.. I will be over 20lbs of boost with 10.5 compression.
I am kinda scared E85 may not be enough honestly?
Old 06-14-2024, 07:55 PM
C5_Pete's Avatar
<———- Meh… 13.5:1 hot air turbo on E85….
Boost doesn’t kill engines… timing kills engines.
Tune it safely within the limitations of the build, and fuel…
Best of success to you!
The following 2 users liked this post by C5_Pete:
jayyyw (08-17-2024), stage274 (06-15-2024)
Quick Reply: Dart 402 block, 10.5 compression, Tooley Trick Flow cnc heads, F1a blower..
