Maintenance any different than NA
Old Jul 14, 2024 | 11:12 AM
Mbs1994's Avatar
Default Maintenance any different than NA
Hello all,
I just recently picked up a 00 trans am with a d1sc and just wondering whats different when it comes to maintenance. I have seen they use different spark plugs, id assume to still run 5w-30, i ordered some procharger oil and plan on changing that out. Anything else to look for? I'm replacing the brakes, fluid, and lines. It over heats with AC on so already been reading to upgrade radiator and change my fan set up, might need power steering pump, and a never ending list of others. Any other input what you would check on a 24 year old fbody na or fi.
Old Jul 14, 2024 | 09:33 PM
ScottStaypuff's Avatar
Yeah, more power = more heat so a good cooling setup is a great idea. You will find the weakest links too, rear end, transmission. But I hope Procharger overall is pretty easy maintenance. Hopefully others will chime in.
Old Jul 15, 2024 | 06:49 AM
Mbs1994's Avatar
I've already known about swapping to the lt1 style radiator so that's on the list and upgrading either the singular fan ir adding a second. Thankfully this one is a t56 because i already had to build the 4l60e in the one i just lost.
Old Jul 15, 2024 | 06:36 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I would change the oil more often for sure, it breaks down.
Old Jul 15, 2024 | 08:04 PM
Mbs1994's Avatar
On the engine, procharger, or both? It's only driven on the streets and nothing crazy. I would be interested in a track but also pretty sure they closed the only one in the area
Old Jul 16, 2024 | 11:30 AM
LS1Tech Co-Founder
I'd change the blower oil once a year, cheap insurance.
My buddy drag races his '69 turbo ls Camaro a lot during the year, changes oil probably 3 times during the season.
Old Jul 16, 2024 | 11:42 AM
Black_Sunshine_99's Avatar
Not apples to apples but I change the oil in my turbo car annually sometime twice a year because I beat on it which is one of the reasons I use Delo 15-40.
It might be a good idea to up the weight a little bit as well.
More power means more heat which taxes the oil more.
Old Jul 16, 2024 | 07:08 PM
Full Power's Avatar
Originally Posted by Mbs1994
Hello all,
.......................... 00 trans am with a d1sc I have seen they use different spark plugs,
i.
. YES. VERY important to use Colder than stock spark plugs. TR6 works okay for low boost in Alaska.
BR7EF probably a better choice if you are hitting it harder than 12 PSI, or running IAT over 110 degrees F.
Old Jul 16, 2024 | 07:34 PM
Y2K_Frenzy's Avatar
Make sure the crank case pressure isn’t excessive. if it is it’ll eventually start blowing out seals and gasekts. That’s the boat that I’m currently in with a non GM product.
Maybe look into deleting PCV if it still has it.
Old Jul 17, 2024 | 08:11 AM
Old Buzzard's Avatar
An occasional look at the plugs and a data log might help head off an issue.
Old Jul 17, 2024 | 11:24 AM
Mighty Mouse makes a great PCV catch can that works very well if the OP wants to retain PCV function.
Old Jul 17, 2024 | 12:04 PM
Kjduvall's Avatar
everyone above is right, br7ef gapped right, better cooling ( i ran a 180 thermostat as well) , catch can ( i liked mine vented, cause i blew out some seals too) i always changed out the procharger oil every other oil change about 6k mi plus its pretty cheap. couple things that are nice to have, a drain line on the unit to make changing the headunit oil easy, a boost gauge, change the bov to the big red one ( it sounds bad *** and leaks less than the stock black valve plus can be rebuilt with a parts kit) i dont know what rear is in your car but start saving for a s-60 if its stock. also keep an extra belt in the car just in case, make sure the idler is in good shape cause belt slip sucks. and my personal favorite couple smaller pulleys to play with when you just need more down the road. sounds like a fun project happy wrenching sir.
Old Jul 19, 2024 | 06:53 AM
Mbs1994's Avatar
I appreciate you all so much. I'll be starting some maintenance the next couple weekends and have a good list now of where to start. I thought I needed brakes but have since learned the car was in a accident so it might be that instead. Hoping to get a good look over soon.
