S369 on a mild 5.3
550/600 hp and quick spool is the goal. Fuel system was built for boost and E85 in mind.
Alum 5.3, 10.1:1, Texas Speed CNC Ported 799 heads, Tick Stage II 4.8/5.3 turbo cam: 219/223 .617/.595 LSA114+3, Dorman LS2 intake, LS6 front manifold, 2" crossover, modified truck turbo manifold with the turbo hanging off it. 2920 lb vehicle weight, 6 speed manual, 3.091 final drive. Manual boost controller, wastegate set at 3.5 psi and it starts creeping at 4000 rpm and reaches about 6 psi at 6800 rpm.
If I floor it at 2200 rpm in 3rd, I have 1.5 psi at 2400 rpm 3 psi at 2700 rpm.
I did modify the compressor housing to enlarge the gap in an effort to make the turbo flow more at low pressure ratios. So far I really like it!
Stock:
Modified:
Though as pictured the s369 has flow issues at the boost levels most v8's run. Its really made for higher pressure ratios on smaller engines. The S366 has a compressor cover more like the modified one above. I'd call Jose and ask which S3XX is best suited for your goals. A worked S366 from Jose may make more than a box stock S369. Another member on here switched from twin S366 to S369 and lost power. Then went to precision 66's and made like 100+ more whp than the S366's. (on full tilt).
Yup here it is... 11lbs it made 540whp and he ran it at 16lbs. He believed it was 600ish at that level and pretty much tapped.
https://ls1tech.com/forums/forced-in...ngle-s366.html
https://ls1tech.com/forums/forced-in...-pg-8-8-a.html
I've posted the dyno charts and other bits on this forum if you do a search.
Might be something to consider based on your goals?
He did indeed have the DATA.
That 70/70 spooled up damn quick- it was making boost almost 2 seconds quicker than the 78/75.
Stock bottom lm7, 60mm tial wastegate. One single borg warner s369.
It made 727 whp and 1010 wnm (745 ftlb)
1.15 bar/ 16 psi.
So the turbo is quite capable.
Dynoed on a dynapack hubdyno. Found the video of it here: Volvo 240 lm7 dyno and drifting. 727whp 1010nm
Dynapack hubs read notoriously high. Esp. with any correction factors that may be involved. That video proves nothing. You aren’t doubling the NA WHP at 16lbs. And a clapped out cam only 5.3 doesn’t make 363whp. Built a dozen of them... not happening.
Dyno’s are a horrible performance marker, the numbers mean very little. Its just a tuning tool. If we had the cars race weight and trap speed you can get an accurate power estimate.
Several guys have run around that boost level on a 5.3 S36X frame turbo. Its a fun little setup.
