Bad night at the track
Old Oct 31, 2024 | 09:16 PM
jimmyg's Avatar
Default Bad night at the track
So my buddy’s c10 . 5.3/s480 @18 lbs . 93 / meth/water . What would cause this ? Went lean ? Had it tuned . Been done for a while . 2nd time at the track first run .
Old Oct 31, 2024 | 11:16 PM
wannafbody's Avatar
Maybe the head lifted.
Old Oct 31, 2024 | 11:46 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
It was obviously detonating pretty bad on all cylinders in the picture. Without knowing the actual tune, fuel pressure, whether the water/meth was actually spraying, etc., we can only speculate as to the cause of the severe detonation.
Old Nov 1, 2024 | 05:14 AM
jimmyg's Avatar
How can u tell it was detonating in all cylinders? The only thing that changed is he bought a 2 step but I guess he didn't use it at the track , but he was messing around with it on the street the day before
Old Nov 1, 2024 | 07:56 AM
Old Buzzard's Avatar
" he bought a 2 step but I guess he didn't use it at the track , but he was messing around with it on the street the day before".
Way too much info missing to make much more than this being a possibility.
Old Nov 1, 2024 | 09:22 AM
Black_Sunshine_99's Avatar
Depends on how it was tuned.
For example, I bought my buddies car who had it dyno tuned, ran great, no issues.
When I made a full pull thru all the gears say 20-150mph I realized there are a lot of issues that will pop up that don't on the dyno.
Fuel pressure dropped off, threw the belt off, boost controller referenced incorrectly, several problems popped up which never happened to him because it was only ever run for a few seconds at WOT on the dyno.
Post the tune for starters, describe the engine combination, describe the current fuel system, W/M content, when does it come on.
Willing to bet timing was greedy or fuel pressure dropped off at the top end.
Assuming this is on a Holley system, no safeties were in place?
Old Nov 1, 2024 | 10:19 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Did you have a log to look over?
Old Nov 1, 2024 | 03:03 PM
gametech's Avatar
Maybe it is just the way the pic looks on my screen, but that looks like a lot of speckles and pitting all over the combustion chambers and valves. I don't see any of the melting you would get with pre-ignition, so it looks like detonation to me.
Old Nov 1, 2024 | 05:09 PM
LS1Tech Co-Founder
Haven't provided enough information.
Old Nov 2, 2024 | 11:18 AM
forcd ind's Avatar
I would imagine 93 and high boost even with meth/water you were a little on the edge, and if you don't have like an oil sep on the PCV valve, wasn't much room for error.
Old Nov 2, 2024 | 07:10 PM
91 Z28's Avatar
What's the timing at?? Looks like they were a little greedy with it and motor said I can't take it anymore
Old Nov 5, 2024 | 11:21 AM
AwesomeAuto's Avatar
Looks like a timing issue.
Old Nov 6, 2024 | 04:52 PM
Quito195's Avatar
That’s exactly what mine did when I had fuel slosh and it leaned out at 18 psi.
Old Nov 10, 2024 | 07:57 AM
jimmyg's Avatar
I think that's what happened. Gonna look into a baffled tank or a hydro mat . It's got twin 340s in tank . Stock tank . First turbo build so it's a learning curve
Old Nov 10, 2024 | 07:59 AM
jimmyg's Avatar
Got an another 706 head . It's down golens swapping valves etc . He originally put bigger valves in when he did motor
Old Nov 10, 2024 | 09:09 AM
kinglt-1's Avatar
what did the plugs look like?
Old Nov 12, 2024 | 12:21 PM
Its hard to tell, but looking at the plugs in the head from the shot, the timing mark is in a pretty bad spot, which is why I said timing.
Old Nov 12, 2024 | 02:11 PM
Too far up the strap from the bend?
Old Nov 12, 2024 | 02:16 PM
Hard to tell from the pictures, but the cylinder in question looks like the timing mark is on the grounding strap near the body, below the bend.
Old Nov 12, 2024 | 02:20 PM
I thought for pump gas if the mark was closer to the base nearest threads that it meant the timing was low if anything?
