turbo vacuum routing
Currently we have it like this
A line out the back of the intake manifold directly to the vaccum block as the source (car has hydro boost so no vaccum from brakes)
MAP sensor is in the vaccum block
Fuel pressure regulator directly to vaccum block
Blow off valve and waste gate Teed together coming directly from the intake manifold
Is this a correct way to do it? It's how my friend did it lol.
Was thinking about putting the MAP directly into the intake ( the car was running 104KPA at idle which is no vaccum) i've sense then re done everything.
then running the source to the block from back of the intake, everything else like the waste gate, bov and regulator will all be off the block with their own lines.
If anyone helps I appreciate it. Last thing on my car todo, just wanted to make sure it's right
Suggest watching a few YouTube videos on boost controllers. This one taught me a lot:
Ran it that way for a little over year with no issues.
Waste gate was a 44mm Tial and 50mm Tial BOV if that helps.
1. What is the advantage of having the WG connected to manifuld (and thus also vacuum) vs. the compressor?
2. Why is it problematic to have the WG connected to the compressor when running an intercooler?
Would definitely recommend running some kind of EBC.
I ran the Innovate SCG-1 on my last car and it worked great, easy to install, easy to setup with basic features.
My current car has a Cortex EBC and while its way more complex, it offers a ton of great features.
Also, where is the best location to run the line for the fuel pressure regulator from? I have a long line going from the back of the intake on the passenger side all the way around to the driver's side. My fuel pressure never seems to rise 1:1 with boost. If I can T into the blow off valve like 91Z said, I'll have a much shorter line coming from right behind the TB.
Everything vacuum/boost referenced related comes from that using small plastic push lock lines, single small line going to the BRFPR, BOV's, etc. which seems to work very well.
For boost control my Viair compressor feeds air to the 3-port Mac valve at port 1, port 2 goes to the top of the wastegate, 3 is open / vent.
Then I have a separate line going from the compressor to the bottom of the wastegate as pictured below.
When I first got the car, the air from the turbo was going to both Mac port 1 and the bottom of the wastegate with Mac port 2 going to the top of the wastegate which I thought was interesting as my last car I set it up so the turbo air was going to the Mac valve and then to the wastegate only.
All methods seemed to work just fine for controlling boost, the last method however made running a low lb. spring not possible as the gate would open due to exhaust backpressure.
I still feel like boost comes in the hardest and is more stable with compressed air, maybe that's just me though.
. YES, you need to run the top hat port OPEN if you want the wastegate to function correctly on SPRING pressure.
