Turbo 5.3 Boost Falling Off
Both cars have been run up around 14 lbs. on pump fuel only for years now.
Since he's remote, he uses scans from your drives to dial in the tune on the street, so you get a really nice driving car and he'll work with you until you're happy.
I have my solenoid hooked directly to the discharge on my turbo. I have a three port on there at the moment and it gets 10psi max (4 port was acting up, think it was the connector). heres how mine is hooked up as a 4 port or a three port:
Port "A" or "1" (depending on brand) Goes to the top of the wastegate (dome)
Port "B" or "2" goes to the bottom
Port "C" or "3" goes to the discharge on the turbo
If you have a 4 port, leave the 4th port open
If you have a 3 port... then your done. Start low on duty cycle so you get a feel for what its going to do.
heres a diagram for you.
https://www.turbosmart.com/wp-conten...tMuZ3XH2BCZvzW
Get the controller working as the boost will come on faster and steadier.
Plus, you could wick it up a little more on pump gas which you will want to do.
