Oil change interval for Daily-Drivers in Boost.
Oil is cheap.
I like clean oil.
Can always pour Low mile drain oil in the plow trucks, fork-lift, or pour it on old used tires and BURN 'em in the yard on Earth Day.
I just can't seem to allow oil to go 5000 miles, just HAVE to drain it after a few months, seems I ALWAYS find some reason to throw a new filter, and fresh oil in. Never seen it "get dirty".
Anybody actually run oil for a full 5000 miles on Boosted daily drivers?
My philosophy I tell my Mechanics students:
Oil change....hmmm... I don't keep track of it....honestly I let it go so long that one day I'll think, "hmmm, its been quite a while since I've changed my oil....maybe I should consider it sometime this year... or next". I go AT LEAST 6 months and an unknown mileage between oil changes. I do check the level from time to time though. It's usually good.
btw, matter of fact, the oil life indicator in my truck is at 5%. Sometimes I just reset it and change it when I can. As long as it has oil in it, its fine. Oil is not a magic engine fix. Funny how an engine will develop a noise and people are quick to change the oil, like thats gonna fix it. It ain't, the damage is already done.
I change my oil at the end of every summer no matter what because I don't want acidic oil sitting in my engine for six months or more.
If I'm beating on the car a lot or doing events, I'll change it once during the summer too.
I'm sure its way overkill but $50 for an oil change is dirt cheap insurance as far as I'm concerned.
Or add some spacers to the rear hinge bolts and maybe pull the seal so the air can escape.
I love having no hood because all the looks the car gets, my son loves it too which makes it even better.
The delo/rotella is the only oil that I've used that will come back after you let it cool off a bit and its half the price in most cases.
Guys always talk about how it's a diesel oil and it will foam and lose pressure, but my oil pressure logs say different, and the inside of my engine is spotless, so I use it.
Nobody has messed with it so far, I just plan out my trips which I did anyways.
Something like this would on your hood would look dope.
I was thinking of getting a base Camaro hood and doing these since they wouldn't work with the factory SS hood.
Trackspec Hood Louvers FRS / BRZ (2013-2020) Full Center Vents Kit
I prefer the sleeper look, full exhaust with mufflers, and going unnoticed.
Our family has 5 vehicles. I change oil in them all twice a year except the GTO I change 4 times a year. Always have way less miles on them then needed when I charge them.
I use driven hot rod conventional in the GTO and valvoline synthetic in the rest. 10w40 in the GTO cold pressure is 60 and hot is 40.
I change the Procharger oil twice a year.
I’m wrong for changing it so often as I’m sure it’s not needed but I’m not hurting anything by doing it.
