Boosting 11.5CR 416 stroker
Old Aug 21, 2025 | 03:43 AM
ggallaher's Avatar
Default Boosting 11.5CR 416 stroker
New to the ls game…
I recently purchased a car with a ls3 based 416 stroker.
LME built motor, Callie’s crank and rods, forged Weiscos, big PRC heads it’s allegedly in the neighborhood of 600+. The paperwork with the motor says actual cam lift is .638/.629. 11.5:1 compression
Im curious on everyone’s thoughts on running it on pump gas as to how much boost it’d handle. I’d probably opt for a cam change in the process as well. It’s got a custom harness on the gm ecu but I’m looking to switch it to a Holley dominator
Old Aug 21, 2025 | 06:56 AM
bthomas's Avatar
It’s doable, but the error window gets thinner the further towards the edge you go.
Tune will need to be dialed in,
meth injection would be a great idea,
e85 would be better,
Pulling the heads and softening the chambers, as well as verifying the head gasket would be on the short list too.
Old Aug 21, 2025 | 08:58 AM
Black_Sunshine_99's Avatar
I agree with @bthomas but I wouldn't boost an engine with that high of compression on pump gas.
I'd buy E85 by the barrel and switch my fuel system over to that.
I'm in a similar boat in that there is no E85 where I live and I want to make more power than pump gas can safely provide.
A 55gal. drum of E85 is less than $600 and would last quite a while.
If you're moving to a Holley, you could always go flex fuel which is my plan except with a factory PCM.
Old Aug 21, 2025 | 12:06 PM
Forcefed86's Avatar
It won't handle diddly on pump gas. Its already on the edge for even 93 pump gas. Waste of time to turbo it if you don't change the fuel or drop compression.
Old Aug 21, 2025 | 05:08 PM
ggallaher's Avatar
Kinda what I was figuring. Appreciate the input. It was originally a nitrous build but had never been sprayed. It’s mated to a t56 magnum in a first gen Camaro
Old Aug 22, 2025 | 09:44 AM
Honestly, I'd swap the fuel to E85 and run the flex fuel sensor with the Holley.
Set it up so it only makes 4-5 lbs. on pump gas but as much as you afford with 50% E and up.
Keep a 55-gal drum in the garage, if you're out and about and get low and can't find E then pump gas will get you around still.
Plus, you can easily pickle the fuel system if storing the car for long periods of time.
This is also my plan lol.
Old Aug 23, 2025 | 01:09 PM
Old Buzzard's Avatar
Pump 93 and some methanol??
It appears that it mixed with E85 works.
Mixing 40% methanol w pump E85. Interesting results! - LS1TECH - Camaro and Firebird Forum Discussion
Old Aug 25, 2025 | 04:24 AM
ls1 1990 VN's Avatar
That high of a compression, don't even bother trying to boost. It's a NA engine, use Nitrous if you want.
Old Aug 25, 2025 | 10:23 AM
Forcefed86's Avatar
I don't see why people thing nitrous is high compression safe? If anything, its worse. It's a much more violent power adder than boost. Using any real amount of nitrous on pump gas with high compression is also a bad idea. Need good gas for any power added with high compression IMO.
Old Aug 25, 2025 | 01:39 PM
RonSSNova's Avatar
Put the proper dished piston in it would be the cheapest solution.
Old Aug 25, 2025 | 01:43 PM
Full Power's Avatar
New to the ls game…
...........................................11.5:1 compression
thoughts on running it on pump gas ...............BOOSTED ?
. Hell NO....... Might live on E85.... Live longer on straight METHANOL.
You'd have better luck pushing manifold pressure and TUNING a STOCK MOTOR.
Save that stroker for Later- after you practice/learn a bit.
