What do I do with this L92 before I install it?
There was a copo oil pan in the parts forums a little bit ago at a good price, I thought about it but I'm in too deep with the Haltech and new fuel system lol.
And yeah, my hot idle pressure is 35-40 PSI, but my high RPM pressure was starting to drop. If you look at my bearing pics in the other thread, I definitely was having oiling issues. Whether that's from wrong oil, hot oil, foamy oil, pickup clearance, bearing clearance, etc., I have yet to determine. But with so many people having issues with the 10296 pump and stock F-body pan, it just seems like a problem waiting to happen. I don't want to overfill the pan to bandaid oil delivery problems. Don't want to invest a bunch of money in a substandard pan.
I run Delo 15-40, a Wix filter w/o a bypass and plugged the bypass in the filter housing as well.
I wonder if your pickup is too close to the bottom of the pan, that pump moves a lot of oil, and I could see that gap being the issue.
Did you consider an oil baffle pan insert?
LS1 Camaro / Firebird (F-Body) Racing Oil Pan Baffle
Would something like this work?
Moroso - LS Swap Oil Pan (may require oil pickup) | MOR-20145 - ICT Billet
I swear I saw one in the classifieds a while ago too.
An oil accumulator might be worth looking into as well.
I did an oil cooler on my last car using an Amazon kit with its own little fan and it worked pretty good, my temps never really got high enough to require it but it did stabilize my pressure after making pulls.
If I'm you, I'm buying that steel Moroso 7-Qt pan if it fits, the additional capacity would probably help with temps too.
