What do I do with this L92 before I install it?
I've decided the heads have to come off, for a few reasons. 1) Too big of a chance that something fell into the cylinders when removing the engine. I had to pull the intake to get it out of the truck, and it was caked with dirt. 2) I need to inspect the heads for valve guide issues, etc. No point in installing the engine if the guides are shot and it has valve sealing issues. 3) Most importantly, I'm boosting this thing. I have to gap the rings. Every time I see an SBE combo blow up, it's usually due to rings seizing and breaking the pistons. A little extra effort prevents that from occurring.
So that leaves me with not knowing exactly what to do with this beyond that. I have to delete VVT, that's easy enough. I'm on a budget though, so part of me just wants to swap the valvetrain over from my 5.3. The cam will work just fine in a 6.2, especially if I drop my peak RPM down to 6500-7000. It's a 226/235 with a 114+5 LSA, .610/.614 lift. I'd considered just doing a Sloppy Mechanics "Best Cam" as a budget option, but it's slightly smaller and I don't know if it would work that well in a 6.2. There's no real reason I can't use the valvetrain from the 5.3, other than the risk of blowing up the SBE 6.2 and hurting the cam.
Other than that, I have to source an LS3 intake as the L92 won't fit under my cowl, but otherwise it should be a bolt in proposition. So, would anyone have any recommendations as to anything else I should take care of while I'm in there? I'm tempted to disassemble it and have the block hot tanked but leave the cam bearings intact, and reuse the rest of the bearings. I do have a set of .001 larger rod bearings I didn't use in the 5.3 build, if it seems like the stock clearances are too tight. What about reusing the oil pump? It's the Gen IV high volume pump, which seems like it would be okay, but I obviously had some oiling issues with a 10296 pump and a stock F-body pan, and I wouldn't want to repeat that. Do I just source a 10295 pump since I'm leaving bearing clearances stock, most likely? As you can see, there's a lot of things I need to consider. I'd just like some input from others as to what direction to take here.
@lsxfox iirc has an SBE 6.2 that he's been making 1Kwhp with for years now so perhaps he can chime in.
He didn't do much to his iirc and he's been running it for three years I think, I'm sure he'll chime in at some point.
The stock oil pump makes almost 100psi going down the track ive run 15/40 and 20/50 in it with stock clearances
my motor is still together after 200+ passes and a couple thousand street miles its been 7.75@178 in a 3200lb fox
Lmk if i can help with anything else
LS3 Intake Manifold - LS1TECH - Camaro and Firebird Forum Discussion
Assembled 255cc Intake Runner 72cc Combustion Chamber | LPC
