need help please -- problems with twin turbo setup still
2000 T/A
stock shortblock
ported 6.0 heads (Noyzee's old heads)
Cam motion hydraulic cam -- small, similar to Noyzee's old cam
bosch external pump
braided line front to back including return line
Noyzee's twin turbo setup complete down to the oil pan.
Here is the problem. The passenger side manifold heats up to red hot at IDLE in about 5 minutes (driver side is totally fine). This is still initial startup basically -- the car has not seen anything above idle yet.
Pressure is dead on at 58psi and rock steady.
I found some exhaust leaks and fixed those, that didn't fix the problem. Checked the turbo -- spins freely so thats allright.
Then swapped the injectors side to side -- still didn't fix the problem so I'm sort of stuck.
I'm getting a misfire from cylinder 1 (don't know where that is coming form yet but that wouldn'g cause the other side to heat up like that????)
And the passenger side 02 is reading .800 V at idle.
Any help would be great cause I need to get this thing running!!
Swapped 02 sensors allready -- forgot to mention that.
Can't swap the turbos as one is "clearanced" for the driver's side.
I was wondering what do you do about the wires they look like there in there pretty close to everything,
also do you happen to have any sort of instruction manual for the kit?
thanks alot
ed
Something to check
Talking with a friend last night I also came up with to much preload as a possibility. Thats the next thing.
