So I made some shake down passes today....
Old Jul 31, 2004 | 10:53 AM
  #41
Caveman's Avatar
10 & 11 Second Club
Awsome quick runs and not even pushing it 100%. Those front wheels look like the Weld Aluma Stars, what size are they. I was told by Weld they would`nt be good to use on our cars cause of weight.
Old Jul 31, 2004 | 10:56 AM
  #42
y2khawk's Avatar
Originally Posted by Reckless
Nice Matt Going to Thunder?
Hell yeah I am
Mike and Steve bringing the formula??
Old Jul 31, 2004 | 10:59 AM
  #43
y2khawk's Avatar
Yep, they're the one piece Alumastars. 15x3.5 w/ 2.25"BS, I was trying to tuck the fronts in a little more than before, thus the 2.25 BS. The Stange spindles moved them in just a hair as well.
I wanted the weigh the car as well yesterday, but the scales weren't on.
It doesn't see much if any street duty anymore, so i'm not too worried about them. I do have a full set of prostars for street warfare
Old Jul 31, 2004 | 11:15 AM
  #44
Checkmate's Avatar
Wow
Very nice, congrats.
Old Jul 31, 2004 | 11:20 AM
  #45
69firebird's Avatar
matt,
what size are the rear wheels? those were shap looking
great runs, what are you using for boost control just setting your wastegate springs or a boost controler?
thanks
ed
Old Jul 31, 2004 | 11:27 AM
  #46
y2khawk's Avatar
Those are actually DERTY's wheels. They are the first set of 15" Beadloc's that Weld has made bling bling
they are 15x10 w/ 5" BS, 28x10.5W tire
I've got a normal set of Aluma Stars in the same size, but haven't mounted any tires on them yet. Still haven't convinced myself to drill holes in them for screws
For boost control i'm running CO2 on dual port wastegates. 3psi springs in the gates and direct connection from each turbo to the bottom port on each gate. Then fixed pressure to the top port to raise and lower the boost. I've got all the bits to allow me to roll the boost in after the launch, but haven't got it all setup yet. So i took it easy on the launches.
Old Jul 31, 2004 | 11:34 AM
  #47
XLR8NSS's Avatar
Adkoonerstrator
Awesome Matt........AWESOME!!!
Old Jul 31, 2004 | 11:35 AM
  #48
69firebird's Avatar
thats a crazy boost control setup, nice having the first set of rims too
amazing car man
ed
oh whats that thing put at the wheels?????
Old Jul 31, 2004 | 11:37 AM
  #49
y2khawk's Avatar
Not sure, we could keep the tires from spinning on the dyno past 18 psi
Old Jul 31, 2004 | 11:40 AM
  #50
InvisibleSun's Avatar
CONGRATS! That's amazing! I can't wait to see that car and you drive it to it's full potential! Very awesome!
Old Jul 31, 2004 | 11:53 AM
  #51
Reckless's Avatar
Super Moderator
They said they would be there. I thought they were gonna run with you guys at Norwalk, but guess they didn't get the time off. See you at NPR.
Originally Posted by y2khawk
Hell yeah I am
Old Jul 31, 2004 | 12:33 PM
  #52
granitemonkey's Avatar
Holy ****
Old Jul 31, 2004 | 12:58 PM
  #53
Got Me SOM's Avatar
your car must be FUN to drive! congrats!
Old Jul 31, 2004 | 01:15 PM
  #54
-=Merlin=-'s Avatar
are you using a C5R block?
Old Jul 31, 2004 | 01:17 PM
  #55
BISHOP's Avatar
Congrats Harlan!
Old Jul 31, 2004 | 01:18 PM
  #56
XLR8NSS's Avatar
Adkoonerstrator
I'm pretty sure it's a regular old LS1 block. It's unbelievable what these aluminum blocks are holding power wise.
Old Jul 31, 2004 | 01:24 PM
  #57
LSs1Power's Avatar
Awsome times and especially MPH Harlan. How much boost were u running? I went to your website and the links werent working. We would love to know more about ur setup.
Old Jul 31, 2004 | 01:25 PM
  #58
unit213's Avatar
Administrator
Someone PM Jim @ GMHTP quick!
Old Jul 31, 2004 | 02:08 PM
  #59
2001-WS6's Avatar
Yep, a cleaned up LS1 block and forged internals. Top that off with a well managed Stock PCM and guess what... you don't need to go F.A.S.T when all you want to do is just go FAST.
Rick
Old Jul 31, 2004 | 02:17 PM
  #60
y2khawk's Avatar
LOL @ Dan
Never be in a mag, they don't like black cars
Still a .010 over LS6 block, stock crank and main caps. Good pistons and rods is about all. Nothing real special in the short block. Standard ARP studs and GM MLS gaskets, no O-rings.
6.0L heads worked over by Livernois Motorsports. These heads flow better w/ a 2.020 intake valve than my old heads did with a 2.020 valve or 2.050 valve (had both in them at different points). We also went to a severe temperature 11/32" exhaust valve to keep from melting/bending them like the last heads The change in mid lift flow from my old heads was pretty amazing, upwards of 30 CFM in some places.
good fuel, a "lazy" tune, and right around 20psi. Atleast the glances I got of the boost gauge. My datalogs from the runs should have a more accurate pressure number.
oh yeah, and a new intake manifold
