WarBirds Old QMP Turbo kit.. Dyno# inside
Old 08-03-2004, 06:43 PM
  #41
cablebandit's Avatar
sounds like it isn't getting a tach signal but Harlan will know the prob
Old 08-03-2004, 08:01 PM
  #42
KAOS's Avatar
im an fn retartd. 2 step works and works great. harlen you are the man. its just retards like me that make you sound bad. i had it for 5300 not 3500. my bad. also i hate this tial bov. it was supposed to be whipshhhhhhh. now its ti tit tit tit ti. is there any adjustments you can make to get the whipshhhhhh.
warbird the return off of the turbo was a little loose so it leaked a little. also the pump was having a hard time keeping up with the boost. it dropped to 52psi, no volt booster yet. also keep blowing the dip stick out. rob said i need a one way check valve. oil smoke sucks!! starting to already feel weeker than yesterday. think i need more boost. lol!!!!!!
Old 08-03-2004, 08:05 PM
  #43
Scalpel's Avatar
You're a fucktard. The power you have now is totally useless on the street anyway
Old 08-03-2004, 08:15 PM
  #44
y2khawk's Avatar
You can trim a coil or 2 outta the spring in the Tial and make it pop open easier. That'll make the woosh you're looking for, or just turn the boost up, they stay open more with more boost
Old 08-03-2004, 08:21 PM
  #45
Scalpel's Avatar
Daniel, leave the BOV alone. It's doing it's job, fucktard
Old 08-03-2004, 08:25 PM
  #46
NKAWTG...N
StoleIt's Avatar
congrats! excelent numbers! add another thing to my to-do list...damn this list is long...
Old 08-03-2004, 08:28 PM
  #47
KAOS's Avatar
its just not the sound i was looking for. hope that it will start to break in after a while. yesterday it wasnt even all that noticable. now you can tell its there, i guess thats what that sound is. also today when i got on it a little it was up to 11psi, not sure why it went from 9-11 but i turned it back down to 9. like im saying doesnt feel the same as yesterday. shouldnt be messing up yet should it? or is it just me
Old 08-03-2004, 09:04 PM
  #48
CHRISPY's Avatar
blowing out the dipstick is bad news.. Hopefully the check valve will solve it. If it doesn't you have other problems internally...
Old 08-03-2004, 09:42 PM
  #49
KAOS's Avatar
what else could be the problem? rob said the check valve should solve it. i dont want to get into a lot of hassle just now starting out
Old 08-03-2004, 09:52 PM
  #50
LINGENFELTER SS's Avatar
If Rob said the check valve. Well look into it. Dont panic .
Old 08-03-2004, 09:53 PM
  #51
KAOS's Avatar
you got it. i pray the check valve fixes it
Old 08-03-2004, 10:45 PM
  #52
Turbo Addict
RICE ETR's Avatar
that's what i did.. because of my cam, my vacuum is less of course so my HKS wasn't opening and the turbo was surging, popping the TB hose off... so i trimmed off enough just allow a slight preload on it... works like a champ now.... and i get a nice psssssssssshhhhoooooooo.. he he
Old 08-04-2004, 12:10 AM
  #53
LS1Tech Co-Founder
Pro Stock John's Avatar
Received 1,141 Likes on 741 Posts
Yah and have to keep an eye on crankcase pressure Kaos. I run a Metco breather in place of the stock oil fill cap.
Old 08-04-2004, 12:37 AM
  #54
2000 ws6's Avatar
Yeah a Metco valve cover breather and a checkvalve will fix that Daniel.
Another guy we know with a powerdyne ls1 had the same problem and he put a checkvalve in and it fixed his dipstick issues.
Old 08-04-2004, 05:00 AM
  #55
KAOS's Avatar
how do it trim it, also does it work a little better when it gets broken in
Old 08-04-2004, 10:26 AM
  #56
Rob Raymer's Avatar
Daniel, add the Metco breather and a one-way check valve from ATR (Apllied Technologies & Research). That should take care of the problem. But like I told you from teh beginning, it's still a stock motor with 65k miles that now makes DOUBLE its' stock HP. With pistons and piston rings that were never intended for boost.
And don't forget, keep that boost down until you at least install a Volt Booster! And shift EARLY(5200-5500MAX)!
Your boost variance from the 9 to 11psi is the main reason I don't use the manual controllers anymore. The E-Boost actually controls the boost electronically, and has Overboost protection. So it's Set it and Forget it. Might wanta think about getting one.
West Side.
Old 08-04-2004, 10:36 AM
  #57
CHRISPY's Avatar
If there is no piston/ring damage the checkvalve should fix it.
If you have cracked ringlands/melted piston the checkvalve wont help. you'll only end up pressurizing the crankcase through the loss of ring seal vs through the valvecover/PCV
Old 08-04-2004, 10:51 AM
  #58
Turbo Addict
RICE ETR's Avatar
Also regarding the MBC... I don't know where yours is mounted but i have seen one that was installed in the engine bay and the boost would vary depending on how hot/cool the controller was. Once it was moved to inside the car where the temp is much more stable, the boost stayed where it was set.
I found two K&N breathers at a local speed shop that I slipped over the oil fill neck and the pcv fitting on the driver side valve cover as well. Knock on wood... i don't see any puffing out of them yet..... I'll keep my fingers crossed for us both
Old 08-04-2004, 10:55 AM
  #59
LS1Tech Co-Founder
I don't like putting a filter in the back pcv hole on the driver's side cover, if the breather is low oil will slop out on accel and decel.... been there. It's a fire hazard.
Old 08-04-2004, 11:01 AM
  #60
Turbo Addict
RICE ETR's Avatar
hmm.... the back one isn't wet with oil, but I might just remove it to be safe.... the front one is large enough anyways I think.
Quick Reply: WarBirds Old QMP Turbo kit.. Dyno# inside
