Car is now at QMP.
Old Aug 8, 2004 | 08:41 PM
U-Luze's Avatar
Default Car is now at QMP.
Hopefully this is the final round now. Im getting the cam changed out and dynotuned and street tuned. So hope now it will run better. 7.00 at 100 mph is pretty pathetic for a blown 400 in stroker. It will be done in about 2 weeks. Justin
Old Aug 8, 2004 | 09:13 PM
KAOS's Avatar
they will take care of ya, rob is great
Old Aug 8, 2004 | 09:27 PM
LINGENFELTER SS's Avatar
Sweet, cant wait for the #'s. QMP is excellent !
Old Aug 9, 2004 | 12:46 AM
BIGBOS's Avatar
I'm upgrading to an F1 and getting a bigger cam, should be interesting to see what you put out, what are the specs of the cam and how much boost?
Old Aug 9, 2004 | 05:14 PM
U-Luze's Avatar
He is goin to dyno it before and after, He told me the cam is one of the major problems why its isnt running. My headers were coated it burnt the coating off up by the exhaust ports. It was lean on the exhaust side bad. It was working against itself. Maybe rob will chime in and explain what it was doin. The cam will be a custom grind lunati. I have no idea what it will be rob will pick it out. Hopefully the car finds the missing boost and picks up a shitload of power. All i know is im ready for it to make some serious power, and lays down some impressive passes. Justin
Old Aug 9, 2004 | 05:16 PM
U-Luze's Avatar
Oh yea on the boost, havent a clue its pullied to spin at 68,000 rpm. I hope to see 18-19 lbs if it dont slip.
Old Aug 9, 2004 | 05:33 PM
BIGBOS's Avatar
Hmmm, thats right around where I'll have mine, what kind of gas are you using?
Old Aug 9, 2004 | 05:38 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Good luck Justin... Who built that 404ci?
Did you check for belt siippage when it only went 100 mph in the 1/8th?
Old Aug 9, 2004 | 05:53 PM
U-Luze's Avatar
I use Torco 118 gas. I am thinking about puttin alky on it also. But for now run straight race gas. Joe Jolly of LPE built the motor. He dont work there anymore. The belt was never touched when i ran the 100 in the 1/8. It varied all night long 97 - 100
Old Aug 9, 2004 | 05:57 PM
LS1Tech Co-Founder
My 136 pass was a shakedown (105 1/8th) but based on my pulley combo I had to be getting some belt slippage. I'll hopefully get the car out in the next 7 days and will buy a shorter belt and see how the car does with no other substantial change.
Old Aug 9, 2004 | 06:03 PM
U-Luze's Avatar
You think 115-117 is possible in the 1/8 with no belt slip and the extra cubes? The power came on immediatly with the blower. I seen 14 lbs at 30' out it left on 9 lbs. Hope now it will make more on the brake since it will be setup correct this time.
Old Aug 9, 2004 | 06:08 PM
LS1Tech Co-Founder
Well 115-117 @ 1/8th is closing in on Harlan's 119mph 1/8th.
So I will say... Dunno.
You have all the parts to go that fast it's just a matter of whether they are all working right. What is your raceweight?
Hey do you remember that girl at Club Paradise, you said she was studying to be a cop? She had dark hair and a little tattoo?
Old Aug 9, 2004 | 06:19 PM
U-Luze's Avatar
Car weighs 3225. I still got lil more stuff to rip out. I sure hope like hell all the parts are working in conjunction now. Its seems like i bought a car that was suppost to be fast from the get go and had to end up dumping 5,000 plus the motor. The guy who helps me work on it wants me to back halve it and put 31x10.5W's. That way i can get it down to about 2600 without me in it.
Old Aug 9, 2004 | 06:21 PM
U-Luze's Avatar
Oh yea i remember her. She was a hot ***.
Old Aug 9, 2004 | 07:48 PM
BIGBOS's Avatar
The car has gone fast before........I've seen it go 10.3's
Old Aug 10, 2004 | 10:45 AM
LS1Tech Co-Founder
Well you have the parts to go high 8's it's just a matter of making them all work together. Might take 5-6 runs to dial in the combo. With my car we were changing the tune between passes but also lost a belt on the 2nd run. I really did not have very good belt tension on the 10.3@136 since I was in a hurry (track rental was over) so I expect to pick up just from getting the tension right.
Old Aug 10, 2004 | 04:10 PM
U-Luze's Avatar
Yea BOS i've seen it run that at Bowling Green when the last N vs S race was. Ive been thinking hard about putting Robs Alky kit on my car also, It looks pretty nice way its set up. Has the tank molded like the battery and gos back where the battery is, looks like factory. My car has an 8'" conveter that go's 5100 on the brake. Would i benifit from a Neil Chance unit? Best 60' ive seen so far is a 1.49 on the back tires. Id like to be in the 1.3's. Im just down to the nitty gritty now on getting it all ironed out. Time will tell.
Old Aug 10, 2004 | 04:29 PM
LS1Tech Co-Founder
5100 stall sounds like you should keep it. Just make sure that you aren't seeing belt slippage during your pass. Sounds like if you made 15 off the line and 9 down the track you had huge slipppage or something else needs work.
Old Aug 10, 2004 | 04:33 PM
SS00Blue's Avatar
C'mon, John. You know you're off topic. Plus the fact that you're really posting to a topic that should be a personal taboo for you. For once take some subjective advice, though it comes from someone that has publicly exposed your faults. It's really something you could ponder, if you're mature.
SC-
Old Aug 10, 2004 | 04:35 PM
LS1Tech Co-Founder
? No idea what you are talking about.
If I pull out my converter I will go BIGGER than my 4200 thanks. Like to a 4800.
