How much boost before pump gas will not work?
Ive just heard that the lower the compression the less streetable (with pump gas) it becomes. Just trying to get the right combination (CR/PSI) for max potential..
NOGO said it was like 900cfm. Guess ill have to give ATI a call and see what CFM the D1 flows.....
http://www.procharger.com/models.shtml
From an ATI document:
You have to sift through the generalizations when you design an FI setup.
A boosted 427ci could make 800rwhp on pump gas no problem. Keep the compression low. Go 8:1. One point of compression reduces power by 3%. That's not very much. When folks talk about laggy low compression engines they are talking about heavy 4 and 6 cylinder cars.
Tangentially my 746rwhp setup made 600rwhp at 5200 rpms. I was making 550 around 4800 rpms. So I probably make about 450rwhp at 4000 rpms.
Whenever I see folks advocate more than 9:1 compression for an LS1 I don't think they have personal experience with this stuff and are just passing on what JoeBobBuilder told them.
Back on target. Well I think an 8:1 348ci could hit 800rwhp on pump gas with a FMIC and no alky. I think a 427ci could do 900rwhp at 8:1 without aids, maybe a little help. Remember we are modding one of the most effecient and well designed engines that has come out of GM or Japan in the last 20 years.
Sounds good. I guess ill go with an 8:1 CR on the motor and buy the F-1.. That should be enough boost.. I think the ATI procharger is the best on the market for boost that i have seen. What do you guys think? FMIC?? What does sthat stand for Pro Stock John?
-Kevin
-Kevin
-Kevin
D1 SC Supercharger @ 14-15 psi at peak HP.
There's another thread floating around where I posted all the specs.
