How much boost before pump gas will not work?
Old Aug 9, 2004 | 11:09 PM
waterbug1999's Avatar
Default How much boost before pump gas will not work?
Looking into getting forged block and boosting the hell out of it with a S/C. But when is too much boost gonna make me run race fuel. Someone told me 15psi but was reading another thread and saw were the cobras were around 20psi. So that confused me. Can someone shed some light please. Thanks
Old Aug 9, 2004 | 11:23 PM
Mike 01WS6's Avatar
All depends on your compression ratio/timing/tune/heads/cam/and quality of gas. Too many variables to put an exact figure on it. But many members on this site have been using methyl/alky/water injection to run more hp on pump gas.
Old Aug 9, 2004 | 11:32 PM
First i am gonna buy the d1sc kit and keep the car running. After that, start the build on LC 427. What would be the ideal compression to maximize the S/Cer. Just doing some home work before i dish out all the cash. Thanks
Old Aug 9, 2004 | 11:59 PM
Mike 01WS6's Avatar
Well since you are increasing the cubic inches of the motor, you can run more power on pump gas. A streetable F/I motor would be about 9.0:1. Some have gone 8.7 or 8.5:1 for higher power levels, but you will lose some streetablility.
Old Aug 10, 2004 | 01:39 AM
NoGo's Avatar
I used to think compression ratio's in the low 8's would show up in the drivability, but honestly the cars still seem to run fine. The only difference you will notice is that the car will be a turd without the blower or turbo.
FWIW, we had a 99' Cobra owner come in and put down a rediculously low dyno number. (210 or something). I couldn't figure out what was wrong with his car so I started asking him about is blower motor that he just put in. I did a few calcs concerning his compression ratio and it came out to something like 7:1. The car still ran fine with no drivability problems, but was just a complete dud.
Old Aug 10, 2004 | 02:25 AM
Just trying to figure out what my options are... Want a nice streetable Supercharged 427 to show off, drive around town as well as go to the track and blow some peoples doors off as well..... What kind of power you think that will put down?
Old Aug 10, 2004 | 02:33 AM
NoGo's Avatar
Big power on pump gas.
8:1 Compression
Custom Front Mount Intercooler (very important)
Custom Tubing
Blower Heads
high 220 to low 230 'ish cam
Pin the crank
ATI SuperDamper with custom 7.25 SC crank drive
SDCE Drive System
ATI D1
RR Supercharger Pulley (3.2)
LT Headers
Stock Catback (or something else mildly restrictive)
All said and done you should have a streetable 700HP running 17 psi on pump gas.
Good Luck
Old Aug 10, 2004 | 02:42 AM
8:1 Compression
Custom Tubing
Blower Heads
Pin the crank
SDCE Drive System
ATI D1
LT Headers
Good Luck
Yea, I am going with the ATI D1 kit. So i believe it has the 2 front intercoolers. Will bolt that up to my stock motor till i get the 427 built. Should get it in a few months. Just got a DUI so im paying 5K for that
Old Aug 10, 2004 | 02:50 AM
NoGo's Avatar
Skit the two front mount intercoolers, they will end up holding you back with the 427. You need to build the boost to make the power. The intercoolers max at something like 900 CFM. You will need to flow close to 1300 CFM to make the proper boost.
-Kevin
Old Aug 10, 2004 | 03:00 AM
-Kevin
How do you go about doing that? Get 2 bigger intercoolers? Where can you get it?
Old Aug 10, 2004 | 11:38 AM
NoGo's Avatar
Get a big front mount. It isn't cheap, but it is the way to go as far as power is concerned.
Old Aug 10, 2004 | 01:01 PM
Slowhawk's Avatar
LS1Tech Sponsor
For your goal and the 427 I would build the motor for 9.5-1 to 10.0-1 compression and a stage 3 head with 2.08/1.60 valves.Cam in the size of 238/250 on 115lsa and the D1 setup for 10psi (which will be near max on a D1/427 combo).Of course you'll need a good set of headers and the front mount intercooler would be very useful.
I could see this setup pushing over 700rwhp very easilly on pump gas.
Old Aug 10, 2004 | 02:26 PM
MIGHTYMOUSE's Avatar
big displacement and low compression get pump gas numbers.... however it would be cheaper to get a methanol kit than to build a 427...but only by about 5 grand.
if you go big displacement like 427, that will give you good grunt.. enough to drop the CR to 8.5 or so and then i do think you could do 700rw.. thats what LPE does.
Old Aug 10, 2004 | 05:38 PM
Guess you are talking about the front mount in front of the radiator? Is there enough room for that, plus a tranny cooler you think?
Old Aug 10, 2004 | 05:39 PM
I could see this setup pushing over 700rwhp very easilly on pump gas.[/QUOTE]
Thats my goal..
Old Aug 10, 2004 | 06:44 PM
kbracing96's Avatar
Wasn't there a article in last months HOTROD about a competition for the fastest pump gas cars? I think the guy that all most won was running like a 9.08 with a twin turbo 406 small block. I think he would have won, but they averaged 3 passes and on his 3rd pass, he had a fuel system problem and only ran like a 10.50 or something. You might want to check it out.
Old Aug 10, 2004 | 08:48 PM
O.K.. Wll see what i can find.
Old Aug 10, 2004 | 09:48 PM
eviltwins's Avatar
All I have to say is **** that. Have you ever driven a car with 8:1 compression that is not a 4-cylinder? Low end is fine. You will not notice it, period. When you are out of boost part throttle it doesn't matter how much horsepower you have because you're just cruising. When you crack open the throttle and want to haul ***, you want to run more boost to make more POWER. High compression just holds you down. If stock cobras with 60 less cubic inches can run 8.5:1 stock, do you really think that a 348" LS1 should be limited to 9:1 or else you're going to lose streetability? There is nothing wrong with 8.5:1, or even 8:1 compression on a V8, PERIOD. My talon with a ****-ant 2.3L 4-cylinder has less than 8:1 compression, and the car still weighs over 3000 pounds. If low end power is fine with less than half of the displacement and less than 8:1 compression in a 4-cylinder, why would low end power all of a sudden drop off and your LS1 would not be able to even run on the street with anything less than 9:1 compression? Give me a break, it's a load of garbage. I don't know who started it, but it spread amongst the LS1 ranks like wildfire. Everyone here runs 9:1 or 9.5:1 because they think they're going to lose low end. Look at PSJ, he says FLAT OUT that if he did it again he would go 8.5:1 or lower.
Old Aug 10, 2004 | 10:02 PM
F8L Z71's Avatar
12 Second Truck Club
No fear os low CR here
I ran 8.5:1 on my lil 306ci Mustang GT with only 9psi out of a Vortech S-Trim and there was no drivability issues or sluggishness at all. We are also talking about a car that had zero "tuning" besides what you could do with a distributor and a fuel pressure regulator LOL. I still maganed to run 11.82 in 105 deg temps on radial T/As and lifting before the end. Hahaha
Maybe PSJ can chime in...
Ive just heard that the lower the compression the less streetable (with pump gas) it becomes. Just trying to get the right combination (CR/PSI) for max potential..
