Still Over Boosting....help!!!!
Old Aug 15, 2004 | 12:19 AM
KAOS's Avatar
Default Still Over Boosting....help!!!!
ok i took the waste gate off and sanded off the rust and made sure it was free. all parts were all cleansed and lubed and moved freely as individual units, did not try to move them as a whole. i assumed it should work as a unit. any ways. put the waste gate back on and still over boosting according to the gauge. this thing feels like a dog. it wont even turn the tires over from a slow roll. in indy when it was tuned i couldnt even give it any gas and hold it on the road. from a 70 kick in 3rd it was all over the road. tires spinning and throwing rob and me all over the place. i dont know what else to do. any info would be nice.
Old Aug 15, 2004 | 02:14 AM
LINGENFELTER SS's Avatar
Take it to Rob. I would.
Old Aug 15, 2004 | 08:34 AM
KAOS's Avatar
would like to fix problem my self to save a little cash. wish somebody would throw me a couple of ideas as to what is going on or if they have ever had this problem what did they do
Old Aug 15, 2004 | 09:43 AM
Scalpel's Avatar
Too bad you couldn't swap a different/new wastegate on.
I'm at a loss now.
Old Aug 15, 2004 | 09:53 AM
squirrel masta's Avatar
From: its as intense as the time i forgot how to sit down
i have a severe boost drop problem and am still working on it,i think i have it figgured out,if/when i get it done ill let ya know and maybe you can send me some pics of how the kit is set up and ill see how it looks compared to mine,also are you running a boost controller, if so which one
Old Aug 15, 2004 | 09:56 AM
Scalpel's Avatar
He's not having boost drop problems, never has. It's overboosting. This means the boost climbs and climbs, never falls, as long as you're into the throttle.
It's not boost spike or boost creep.
The kit worked perfectly at Robs, he trailored it home, tried to drive it the next day and this is what he's dealing with.
He's tried it with no MBC and MBC, same result.
Old Aug 15, 2004 | 10:50 AM
Unusual T/A's Avatar
Why not use a turbosmart eboost?
Old Aug 15, 2004 | 11:09 AM
MIGHTYMOUSE's Avatar
get a methanol set up and don't worry about the overboost it will come back down eventually.
how does it feel slower with more boost?
Old Aug 15, 2004 | 12:29 PM
Scalpel's Avatar
His ball/spring MBC worked fine when it was being dynotuned, held 9 PSI across the board.
He's ran the setup with and without the MBC and still gets overboost, not spike or creep.
It worked fine after it was dyno tuned, put on the trailor, brought to his place and then it doesn't work, regardless if MBC is on or not.
Old Aug 15, 2004 | 12:30 PM
Scalpel's Avatar
Overboost doesn't fall down, it continues to climb as you increase RPMs. Boost spike and creep can come back down.
Old Aug 15, 2004 | 12:36 PM
KAOS's Avatar
it feels slower. and eboost is not an option as of right now. i dont think the controller is the problem. i can not even turn the tires over from a slow roll but it is still holding oil pressure fine and no smoke anywhere. and as far as it coming back down i bet my life it will come back down when a rod goes through the side of the block. need some real advice please
Old Aug 15, 2004 | 01:29 PM
i agree the controller is not the problem
you wont break a rod fwiw..piston maybe..
you got the pcv set up straight right?
try a lighter w/g spring?
hmm what is the rest of your exhaust situation? sounds like something is stopped up?
Old Aug 15, 2004 | 03:00 PM
Scalpel's Avatar
It's the same as when it left Rob's.
It still over boosts with the MBC installed and working properly. If it was a spring issue shouldn't it be overcome with the MBC since the MBC worked before to raise the boost from 5 PSI to 9 PSI at Rob's?
Same as it left Rob's, no mufflers, just the intermediate pipe.
Old Aug 15, 2004 | 03:01 PM
Scalpel's Avatar
I still believe it has something to do with the WG even though he cleaned and lubed it.
Daniel is going to hook up a different boost gauge to be sure the current boost gauge is reading boost correctly. If it is, I'm still saying it's the WG.
That's the only scenario that can explain overboosting. If the WG doesn't open then you can't bleed off excess boost pressure thus boost just continues to climb.
Old Aug 15, 2004 | 03:25 PM
Scalpel's Avatar
Daniel, here's something to consider:
A wastegate can be caused to stick in two areas. The shaft enters the exhaust housing, the other end of which is attached to the actual valve. The shaft can become stuck inside the housing. Remedies include doses of Liquid Wrench or penetrating oils while GENTLY tapping around the area. Use common sense so as not to tap so hard as to crack the housing! Do this while pressure is applied with your pressure tester, and you may actually be able to see the rod "pop" free as it becomes unstuck. Also common is a wastegate becoming stuck due to carbon build-up on or beside the valve seat. If this is the case, shame on you, since regular heavy boosting will usually prevent this from happening! Again, applying penetrating fluids to the valve seat while GENTLY, GINGERLY tapping about the area will often free the valve. You may want to try a light tap on the valve itself to break the carbon build-up.
Old Aug 15, 2004 | 03:28 PM
Scalpel's Avatar
Take the entire wastegate off of the car. It's gonna be a PITA but it's gonna be the best way in the end and will end up saving you even more time.
Old Aug 15, 2004 | 04:52 PM
Rob Raymer's Avatar
(sorry, just got back in town a few hours ago)
I'm confused. So Kaos DID or DID NOT completely remove the WG from the manifold and clean it? If he didn't, he needs to. I am VERY convinced that the WG valve is stuck.
Also, regarding not having enough power to spin the tires....then something else has happened also. If it was overboosting as you said, it only takes a split second for the engine to go unsafely lean. Though it is reassuring to hear that it doesn't smoke or anything.
If it did go lean, it may have hurt a spark plug, causing the loss in power. While you are removing the WG for cleaning, check the plugs and wires closely.
If after that you still have the same exact problem, call me.
Old Aug 15, 2004 | 05:00 PM
Scalpel's Avatar
He only removed the top (silver) portion. He did not completely remove the entire WG to clean it that way. I too feel the WG valve is stuck.
I agree with needing to pull all the plugs.
Daniel, make sure all the wires are fine as Rob said, be sure they're not lying on the manifold or too close.
Old Aug 15, 2004 | 05:03 PM
MECHAM's Avatar
get another WG
Old Aug 15, 2004 | 05:05 PM
Scalpel's Avatar
Yep, no smoke, no ticking, knocking, etc.
PS, all my info I'm providing is from Daniel. I have not personally been involved with the diagnostics on-site, per se.
