PCV w/ turbo?
Old Aug 17, 2004 | 12:38 AM
Green Thunder's Avatar
Default PCV w/ turbo?
What is everyone doing with their PCV system?
Old Aug 17, 2004 | 06:25 AM
smokinHawk's Avatar
taking it off and using vents.
that seems to work the best.
Old Aug 17, 2004 | 08:08 AM
OLD BULL's Avatar
Are you seeing any codes being thrown or any related problems from using vents?
Old Aug 17, 2004 | 08:25 AM
RICE ETR's Avatar
Turbo Addict
ditto.... and no codes.
Old Aug 17, 2004 | 08:28 AM
Tiago's Avatar
same here
Old Aug 17, 2004 | 10:55 AM
Thanks!
Are you using multiple vents?
Old Aug 17, 2004 | 12:06 PM
2FAST4U's Avatar
Well I have tryed catch can,check valves, and a EVAC setup! EVAC works the best but then the exhaust will burn oil! On my new setup I am useing the LS6 pcv setup, but a vent on the rear driver side and a catch can vent on the driver side!
I would think with all vented that oil would drip on the exhaust headers? That is why I have the catch can!
Old Aug 17, 2004 | 05:50 PM
libertine1015's Avatar
I am switching to the Mighty Mouse method. Breathers on both sides with the hose from the LS6 valley cover going to the inlet hat in front of the turbo. Should be a nice draw through type setup just waiting to get my car back from the shop.
Old Aug 17, 2004 | 09:20 PM
Jammer's Avatar
APE just blocked mine... not sure where the pressure goes...Ape, care to chime in???? I havent really driven the car but that could be an explanation for the oil leaks??? I also donr have any breathers... kinda spooky!
Old Aug 18, 2004 | 12:24 AM
69firebird's Avatar
jammer,
do you have any pics of your setup on the car? or any of the piping routed
thanks
ed
Old Aug 18, 2004 | 06:05 AM
smokinHawk's Avatar
could casue oil leaks or your dipstick to pop out, id put some breathers on.
Old Aug 20, 2004 | 01:28 AM
Jammer's Avatar
Yup... I'll get them to you when I get a few minutes..its easier than it looks.
Originally Posted by 69firebird
jammer,
thanks
ed
Old Aug 20, 2004 | 01:29 AM
Jammer's Avatar
The oil is on my pan and on the pan bolts... but not sprayed around aother than a little on the k-member...but the dip stick remains in place so it could be from elsewhere...turbo connections etc... I'll get on it now that the tranny went in tonight.
