how much timing and timing at diferent rpm's?
runing a t76 on a 6.0 with a cam. i am up to about 13psi and 18deg of timing and runing a 50/50 mix of 92 an 118fuel. i plan on going to 15-18psi soon and maybe runing strait 118fuel.
i just set my timing with one big block all at 18deg. it has been sugested with the fuel i am running more timing might be better but i am kind of learly to push it much higher. my questions.... is there kind of a limit to how much timing or should i go ahead and try more? should i adjust my timing based on rpm at all or keep it all set to one value? more timing down low or up high?
