follow up
Old Aug 27, 2004 | 09:41 PM
BlwnTA's Avatar
7 Second Club
11-12PSI with Twins @ 5800-6000 RPMS I think....to busy holding on!
Oh yea 408 CU IN......SDCE is great stuff
Mark
Old Aug 27, 2004 | 10:04 PM
NoGo's Avatar
Originally Posted by BOOSTAT4500
Stock engine with a D1SC at 6000 engine rpm I saw 9lbs with a 3.2" pulley. Seemed kind of low to me. This is the 6 rib set-up.
Sounds like something is a little off. Bypass leaking, slip (??), TB stuck?
Old Aug 27, 2004 | 10:09 PM
NA$TY-TA's Avatar
You are spinning the blower slower...... if its a stock motor you are right on track with that pulley. D1-SC?? The stock 6 rib crank pulley is what 5.65"??? All i ever saw with a 3.2" pulley was 7 psi with a Gatorback belt spinning to 6200 rpm. Sounds good to be with a stock 6 rib pulleys...... you are ONLY spinning the blower to 43,434rpm's.
Kyle
Old Aug 28, 2004 | 12:06 AM
buschman's Avatar
Originally Posted by NA$TY-TA
Stock Motor and 3.7" pulley Mike??
Yep Gonna try and see if I can get two years out of the stock block running 11-13 lbs of boost. Probably not a wise idea, but I'm confident I got the right setup to make it work.
Mike
Old Aug 28, 2004 | 02:40 AM
NA$TY-TA's Avatar
Tuning, Tuning, and the SDCE Kit......
Old Aug 28, 2004 | 09:33 PM
BOOSTAT4500's Avatar
I'm pretty sure the belts not slipping and the TB opens all the way. I've actually got 2 bypass valves on it now, 1 on each side. Would that affect anything as far as holding pressure? Right now the car is getting tuned with the new 408 motor so I'm anxious to see if the boost changes much. So far its made 8lbs without spining it to redline, started running out of fuel. The tuner said it's on track to make about 10lbs once there's enough fuel to take it that high. I thought it would drop more with the bigger motor but hasn't seemed to so far. We'll see.
Old Aug 29, 2004 | 12:04 PM
BoostedWS7's Avatar
Hey, guys at SDCE,
I just heard of your tentioner kit for LS1 f body and im very intrested in not having belt slippage problems anymore. I was just on your site, and cant get any info on purchasing..... please help! anybody! thanks. Eric Mcarlo86ss@aol.com
