LS1 Turbo Kit
Jose
some idiot asked this earlier....oh wait it was you
daniel
daniel
6-9 psi if you are using an intercooler with the turbo.
I might have went a lil big on this new turbo though judging from the extra lag. We'll see if it is easy to get used to. The first turbo had almost zero lag.
I'll get my intercooler on it and try to get some real #s
I got the upgraded kit with the GT35 and dual stage boost controller.
On a stock T/A if you don't plan on going crazy with the power then I would get their base kit and used the money you saved on a turbo upgrade and buy an intercooler or a methanol kit. You can make great power on the base kit (410-440 bone stock) and with methanol or an intercooler defiantely more due to MUCH cooler intake air temps. I would recomend bigger injectors and custom tuning though. The really cool thing about this kit is that you can start off small and add peices as you go to acomadate a budget. If you decide to go crazy later you can swap turbos, add intercooling, fuel system, forged motor etc.
We are doing my intercooler this Thursday and I will report on how much of a difference the going from 150deg IATs to 90 or below will make on 5-6psi
I currenly have a stock head, stock bottom end 02 TA, B1 Cam (221/558), Jet Hot LT's, Hooker ORY, built 4l60e, Vig 3200.
What I have in mind is getting the base kit with the turbo upgrade for the T67. My concern is will this produce too much boost for my bottom end? I also plan on getting one of the OBX FMIC's. I don't want to have to go through the bottom end for a year or so but I would eventually like to go lower compression & forged internals & go higher with the boost. Will the T67 be too much and or will the T60 be adequte for when I want to bump the boost up some? I know I will also need to upgrade the fuel system at some point as well. I already have tuning on my car for it's current setup & I have lifetime tuning at MTI for retunes so the tuning isn't an issue. Will I need to upgrade my fuel system since I already have some mods & will be putting the turbo on as well?
Thanks for sharing your knowledge!
You can still just run 5psi with the t-67. It will come on a little later and hit a little harder though. The biggest difference with the t-67 is that it has the capability of making more power. The 60-1 will not be as efficient past about 500 hp where the t-67 will.
Billy
