How to set a bov?
Old Aug 26, 2004 | 05:42 PM
vhgjk123's Avatar
Default How to set a bov? adjuster screw tightened all the way and still leaking
Rob told me in another thread that my bov needed to be set properly before it can be tuned right. So how do you set an HKS blow off valve? detailed instructions anyone please?
Old Aug 26, 2004 | 09:03 PM
Blown Ta's Avatar
go to blowoffvalves.com there is a write up on there for the hks
but this is for the ssq valve i dont know which one you have
hope this helps
Old Aug 27, 2004 | 02:20 PM
vhgjk123's Avatar
Thanks for the reply. They tell you just to tighten down the screw which would normally be perfectly fine.
However, even with the screw tightened down completely, the bov is still leaking. The spring is the 7-14lbs of boost spring and I am running 7lbs so that shouldnt be a problem. I am completely lost and this is the only thing keeping me from getting my car tuned so I can have a good running car. I have been dealing with this for like 2 weeks with no solution. Please help.
Old Aug 27, 2004 | 03:34 PM
MECHAM's Avatar
so..let me get a mental picture here of what you are saying.
turn on the car
car is idling
the bov is leaking air at idle?
