Opinion of Reichard Racing Pulleys?
Old Aug 29, 2004 | 10:31 PM
MelloYellow's Avatar
Default Opinion of Reichard Racing Pulleys?
Wondering why I don't see more people running the RR Pulleys?
Anyone remove them after trying them?
If you tried a RR, did you keep it in your setup?
TIA
Old Aug 30, 2004 | 07:33 AM
mdhmi's Avatar
Already have a custom kit that I am happy with.
Mark
Old Aug 30, 2004 | 09:21 AM
NA$TY-TA's Avatar
Ill probably be buying there 3.3" 8 rib pulley to try next. NoGo is using it and making between 14-16 psi on his 383. There pullies are kinda spendy... $160.... bu i hear they work really well.
Kyle
Old Aug 30, 2004 | 04:28 PM
Thx Nasty.
Am having a custom one made for my setup right now.
Not sure how long the turn around will take.
Just wondering how much and how fast they chew up belts.
Old Aug 30, 2004 | 05:57 PM
8seclt1's Avatar
reichard pulleys, aka "the belt shredder", do NOT work any better then normal pulleys... the reason so many people make more boost is because reichard makes their pulleys in different sizes (meaning smaller) then the manufacture.. You are making more boost because the pulley is spinning the blower faster and you WANT to think your $160 was well spent... In a class like renegade, where you are limited to 8 rib pulleys on your supercharger, we have tried it all. I make over 27lbs on an 8rib setup with normal vortech pulleys with limited slip. I have tried reichards and will go through 1 belt a run with his pulleys. I can get 5 runs out of a belt with the manufactures pulleys... I know of certain renegade teams that are sponsored by reichard that have found more power in vortech pulleys
just stating the facts.
Old Aug 30, 2004 | 10:14 PM
Thanks for the feedback!
Old Aug 30, 2004 | 11:20 PM
BIGBOS's Avatar
I didn't have any luck w/RR pulleys either, they ate my belt
Old Aug 31, 2004 | 01:20 AM
BLOWNMERO's Avatar
Where else can you get an 8rib belt smaller than a 3.4?
Old Aug 31, 2004 | 05:52 AM
NA$TY-TA's Avatar
Good question. Im going to call them and see if i can get a 3.3" with out the slots and holes drilled in it.
I know they sell a 3.2" 8 rib for ATI kits also.
Kyle
Old Sep 9, 2004 | 09:01 PM
10thanvhawk's Avatar
Exclamation get your pulley here..
http://www.superchargersonline.com/p...lley&offset=-1
as low as 2.75
Old Sep 9, 2004 | 09:38 PM
Some people have drilled their own pulleys creating valley/grooves in between the ribs.
1 had better luck using a wider valley with smoother edges than the sharp RR teeth effect. Any comments on drilling your own pulleys for grip?
