372 vs 383
Old Aug 30, 2004 | 07:52 PM
gen 3 bu's Avatar
Default 372 vs 383
has anyone used 372 stroker kit with twin turbos.
cant decide if i should run a 372 or 383
Old Sep 9, 2004 | 09:37 PM
gen 3 bu's Avatar
bump!
Old Sep 9, 2004 | 09:43 PM
NA$TY-TA's Avatar
372 stroker???? as far as i know its not a STROKER.... to be a STROKER you have to increase the STROKE. A 372 is a stock crank 3.622 with a .04 OVER BORE 4.04" bore....... I love my 370ci motor and it is cheaper then a forged 4" crank and i like the idea of a Iron block when running lots of boost.
Kyle
Old Sep 10, 2004 | 01:14 AM
goober35's Avatar
That is what i am going to be doing.
Old Sep 10, 2004 | 01:16 AM
BIGBOS's Avatar
I'm running a 370 as well
Old Sep 10, 2004 | 03:24 PM
gen 3 bu's Avatar
it is a stroker kit with the stock bore 5.7 ls1
3.905" bore x 3.900" stroke = 373.67 cid
Old Sep 12, 2004 | 03:19 PM
gen 3 bu's Avatar
bump!
Old Sep 13, 2004 | 05:38 AM
NA$TY-TA's Avatar
Why would you go with a 3.9" crank when it is the same price for a 4" crank and more cubes for the same price...... 3.905" bore x 4" crank for a 383ci.......... or go with a Iron block with a 4.03" bore a .03" over bore and a 4" crank for a 408ci motor...........I would go with a 383 if you can afford it or a 408 would be better... IMOP
Kyle
Old Sep 13, 2004 | 08:07 PM
gen 3 bu's Avatar
Kyle
this motor is goning into a 1979 malibu i want the lightweight alum block
with the 3.9 stroke you get more piston compression height = longer ring life or sacrifice ring life for better rod/stroke ratio
when finished i think the car will run mid nines on nitto drag radials and pump gas
Old Sep 14, 2004 | 05:20 AM
smokinHawk's Avatar
nines on nittos would require alot of power and fishtailing 3/4 of the way down.
Old Sep 14, 2004 | 10:58 AM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
bu, there are not a whole bunch of 3.900 crank guys running around period. Scat I believe had made a bunch of those size cranks. It's just a rare crank size period so you might not find any FI guys running it.
Old Sep 14, 2004 | 11:44 AM
gen 3 bu's Avatar
it is a goal
Old Sep 15, 2004 | 09:44 PM
gen 3 bu's Avatar
Kyle
what is the final compreesion ht of the pistonwith a 4 inch stroke crank
Old Sep 15, 2004 | 11:38 PM
WS-Sick's Avatar
it is a goal
Good luck I wish I could get into the FI scene but I need to stay N/A for now....student.
Old Sep 16, 2004 | 09:47 PM
gen 3 bu's Avatar
Kyle
chk this link
http://www.lmperformance.com/3323/1.html
Old Sep 17, 2004 | 05:39 AM
smokinHawk's Avatar
eagle is the only one i know with a 3.90" stroke
http://www.thunderracing.com/catalog...vid=3&pcid=119
Old Sep 17, 2004 | 01:10 PM
gen 3 bu's Avatar
i talked to one of the reps/tech guys at diamond pistons a few weeks ago and he recomended using the 3.9 crank and he would make the pistons to match for no extra charge - the advatage is more boost and longer piston/ring life
Old Sep 17, 2004 | 03:07 PM
LS1Tech Co-Founder
Scat and Eagle have made 3.900 cranks. Scat started making them first about three years ago, Mallet used them extensively.
Old Sep 18, 2004 | 03:43 PM
gen 3 bu's Avatar
the mallet cars seem to make decent power too
Old Sep 30, 2004 | 04:51 PM
gen 3 bu's Avatar
bumps
