anyone with a F1-R
Old Sep 9, 2004 | 11:46 PM
BIGBOS's Avatar
WOW, thats large
It looks like it would sit on the bracket at the same rate, so there wouldn't be problems w/alingment, but for sure wouldn't be able to fit the inlet hat on there, I plan on putting some sort of screen setup w/the F1
Old Sep 9, 2004 | 11:52 PM
Parker TX's Avatar
i have a screen setup right now. also i wouldnt have any belt slip if lee @ ASP built me cogs.
Old Sep 9, 2004 | 11:54 PM
BIGBOS's Avatar
COGS SUCK.....
Go with an SDCE setup and you wont regret it, TRUST me, I've been through ALL of it
Old Sep 10, 2004 | 01:16 AM
Parker TX's Avatar
tell me more, my belt keeps trying to walk off the cogs. We haven't been able to solve the problem yet. what about this SDCE set up.
Old Sep 10, 2004 | 01:20 AM
BIGBOS's Avatar
I started off w/the stock 6 rib stuff = SLIPPED BAD
ASP 8 rib stuff w/stock tensioner = SLIPPED BAD
ASP COGS 73T/31T w/stock tensioner = TEETH SKIPPED AT 4K
And onto the best and only answer......
SD - Concepts 8 rib spring tensioner setup, they do a lot of stuff for LT1's as well, I would suggest talking to them, if your belts are walking, its probably because of an alingment issue.....
I run a 53 1/8" belt compared to a 39" I was using w/the stock 8 rib tensioner, this system provides a lot more belt wrap.......
I've seen 11psi so far, with not a lot of tension, and no slip.....
I plan to see 15-16 w/the F1 and the FMIC setup
Old Sep 10, 2004 | 02:05 AM
Parker TX's Avatar
thats the wiered thing is that it aligns just fine, the crank pulley nor the impeller pulley move right now and, even with the tension adjusting, nothing, how much does a setup like this run and how do i get ahold of them. I love this site, where else can you get info like this at 2 in the morning.
Old Sep 10, 2004 | 07:08 AM
MEAN LT1's Avatar
I really dont think you need to be running cogs for your application. There are plenty of LT1 people running the f-1 with out cogs. the great thing about 93-97 platform is that we can run a 12-rib setup insted of a 8 rib like the ls1 peeps. Get the SDCE bracket with the 12 rib pulleys and you'll be just fine.
Old Sep 10, 2004 | 08:26 AM
Parker TX's Avatar
thanks, im definitely going to look into it, sounds like a great idea, I havent heard one complaint so for about the SDCE setups.
Old Sep 10, 2004 | 08:51 AM
BIGBOS's Avatar
Call 1-401-732-4047
Talk to Wendy or Scott
Tell them that Brian referred you........
Setup goes from 500-600 bucks, but well worth it, I plan on using the 8 rib belt I was using w/my D-1SC for 500 miles......on the F1
Old Sep 10, 2004 | 03:06 PM
Parker TX's Avatar
i talked to wendy im having the 8rib sent.
Old Sep 10, 2004 | 03:27 PM
BIGBOS's Avatar
Thats good to hear
Old Sep 10, 2004 | 04:20 PM
  #32
Parker TX's Avatar
only thanks to everyone who replied.
just for ***** and grins i put picks of my car and tahoe and other friends cars up.
http://www.msnusers.com/ParkersToys/shoebox.msnw?Page=1
