anyone with a F1-R
Old Sep 8, 2004 | 11:25 PM
Parker TX's Avatar
Default anyone with a F1-R
i am thinking of putting a f1-r on the ol' LT4 and running 18#s, from a D1SC pullied at 15#s, and i can get the head unit for $1800. Input please.
Old Sep 8, 2004 | 11:41 PM
BIGBOS's Avatar
Man, where can you get it for that cheap.......
I was going to get one, but then I would have to do a custom mounting bracket and that would probably result in me switching the pulley setup........I went with an F1 since it fits the brackets I have already......
Old Sep 8, 2004 | 11:43 PM
Parker TX's Avatar
got a great hook up, wont the f1-r bolt up in place of the D1-SC, also can i street this blower.
Old Sep 9, 2004 | 12:10 AM
nbm00ws6's Avatar
Man is this a new head unit,rebuilt,or used? $1800 is at least $1000 under dealer cost.
From what I have gathered, it's like Bos said, you'll need a different bracket set-up at the least.
Tom
Old Sep 9, 2004 | 02:14 AM
1dirtyZ's Avatar
nope you won't need a new braket. trust me i know. you might need a new intake hat set up though.
is the unit used? cause that is cheap.
now why don't you pulley up the current head unit and save the $1800 for something else?
Old Sep 9, 2004 | 02:32 AM
Parker TX's Avatar
from what i have gathered so far is that the f1 is a more efficient blower at high goost, i have also heard that it is a much more peakey blower. i just want to do my research before i spend the money. i would also like to have a M6 LT4 in the high 9s very low 10s. as for the intake hat i dont use one. just chicken wire
Old Sep 9, 2004 | 07:48 AM
LSs1Power's Avatar
From what i have seen in the vette community is that the F1-R will fit the D-1SC bracket no problems. At 16psi one guy got almost 800rwhp on a forged 346CID. So it looks like a good blower too me with more room to grow. I just hope u have a really low C/R so u can run 17psi on pump gas. I was going with 9.1 C/R on my car since I'm going to run the D-1SC, but after seeing this F1-R i might go with 8.5 C/R and run as much as 17psi on pump gas maybe with methanol/water injection after 14psi just for safety. I think 17psi would be the max u can get out of a F1-R since the vette guy got 16psi on a 346CID with a 3.8 blower pulley and i guess 7.75 crank pulley. Based on his dyno he ran the car up to 6600RPM... That means he is running the blower around 67000 RPM which is almost maxing out the blower. I guess they can squeeze 1 or 2 more psi out of it, but they will be overspinning the blower. I would be really intrested in knowing whats the exact crank pulley size(I hope is smaller than 7.75 so that means more boost for us).
Old Sep 9, 2004 | 08:41 AM
C5kid's Avatar
LS1power the crank pulley is 6.75 i measured mine quick
Old Sep 9, 2004 | 08:46 AM
LSs1Power's Avatar
No i mean on that vette... Not a normal ATI kit. If they are using a 6.75 then thats good news. That means the F1-R have another 3-4psi left in it which is really nice. 8.0 C/R would be ideal if thats the case. I did post the question again on vette forum asking Optic about the crank pulley. I will make sure and do the calculations again.
Old Sep 9, 2004 | 08:54 AM
BIGBOS's Avatar
Hmmm, I wish I would of known that the F1-R fits, I assume you are running one 1dirty, but I got hints of that in the past.......
Either way, I think the F1 will do plenty good for now
Old Sep 9, 2004 | 10:02 AM
Parker TX's Avatar
we are trying to finish my car up in the next two weeks, and it seemed like a great opportunity to upgrade head units, i havent had my d1sc for 100 miles yet, i had the p1sc internals changed. ill probably end up getting the head unit if i dont like it which i know i will, i could always sell it for a little more than i paid for it. i like this forum, most everyone here is helpfull, thanks everyone. Theres always room for more input.
Old Sep 9, 2004 | 10:28 AM
scottywheels's Avatar
i ran an f1 and it is the same size as the f1R just different impellar. I am going to be going with either the F1R or the F2 if I go back to FI.
Old Sep 9, 2004 | 12:21 PM
Parker TX's Avatar
whats the difference between the f1 and f1r?
Old Sep 9, 2004 | 12:51 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
CFM rating among other things... check out this chart:
http://www.superchargersonline.com/content.asp?id=6
So your motor is 8:1? That's what I would do if I had to do it all over again.
Old Sep 9, 2004 | 01:43 PM
Parker TX's Avatar
no one i talk to seems to have confidence in the good ole LT1. I need to get pics on here, hey PSJ thanks for the FMIC setup idea.
Old Sep 9, 2004 | 03:54 PM
LSs1Power's Avatar
Eatrice (the owner of the vette) just answered my question and told me that they are running a stock sized crank pulley. So that means its 6.75 which is really good for anyone who wants to run the F1-R. That means 20-21psi is possible with the F1-R on a 346CID engine. The pulley combo that should max out the F1-R at 6600RPM is 3.55 blower pulley and 7.75 crank pulley. So 8.0-8.1 C/R is the way to go with this blower. Did anyone with F1 blower achieve 20psi on a 346CID LS1? It has 2000 RPM max higher impeller speed, but also around 500CFM less. I was just wondering how much would be the difference giving the same engine and running both blowers at their max efficiency.
Old Sep 9, 2004 | 04:20 PM
LS1Tech Co-Founder
Well Chris S. aka Z8's has a 96 LT1 that has gone 8.92 with a LT1/LT4 engine and a stock intake... 383ci LT1 with hydraulic cam.
Old Sep 9, 2004 | 06:13 PM
U-Luze's Avatar
good luck not getting belt slip. I have an 8-rib setup with an F1 pullied to spin the blower at 69,000. The most boost ive seen is 15 lbs. Id sell it in a heartbeat to have a turbo. Also the crank pulley is 8 11/16 and the blower pulley is 4 3/4.
Old Sep 9, 2004 | 06:38 PM
LS1Tech Co-Founder
Belt slip is not our friend.
I have to spend some real time trying a few things to reduce belt slippage.
Old Sep 9, 2004 | 07:05 PM
1dirtyZ's Avatar
big bos , what ever gave you that idea
zr28 here is a pic of a f1r and a d1sc next to each other.
