700rwhp Lt1?
Old Sep 11, 2004 | 01:46 AM
70Chevelle's Avatar
Default 700rwhp Lt1?
A friend of mine is looking for 700rwhp out of a LT1
hes looking @ doing
383
Ported heads by lloyd elliot
D1SC
and a custom ground cam
Do you think that 700rw is possible w/ this set up, and it will be on a stock pcm
Old Sep 11, 2004 | 08:10 AM
White_Hawk's Avatar
hes looking @ doing
383
D1SC
I have a fiend who has 700 rwhp on his 383 LT1 but he is using an F1, not a D1. In fact, I think he is selling the motor out of it - pm me if you want more info. He is running a FAST too. So the answer is NO! Your friend will probably not hit 700.
-Geoff
Old Sep 11, 2004 | 08:46 AM
Parker TX's Avatar
Bet i could hit 700, on my D1. I'll let you know by the first week of Oct.
Old Sep 11, 2004 | 10:22 AM
TApimp's Avatar
What year lt1 robert? Is it 6 speed or automatic? since he is spending all that money anyways tell him just to give in a buy an after market computer
Old Sep 11, 2004 | 10:40 AM
y2khawk's Avatar
FWIW, we hit 700rwhp w/ a twin turbo LT1 (355) on the stock OBD I PCM and my injector driver box.
6 speed car, so that helps. Heathly cam and AFR 225 heads (i think they were 225's not sure off hand)
Old Sep 11, 2004 | 12:01 PM
MEAN LT1's Avatar
-Geoff
I think your reffering to ART?, his motor is very impressive and put down great numbers for what he has. I just wish could have ran the number at the track like he wanted to.
Old Sep 11, 2004 | 08:05 PM
gator's 99TA's Avatar
i personally think it isnt that hard if the heads, intake, and cam are set up right and you spin the D1SC as hard as you can. even on a stock OBD1 computer. esp if this is a stick car.
Old Sep 12, 2004 | 06:09 PM
blackz93's Avatar
the stock computer shouldnt be a limiting factor...guy around here did 770rwhp with stock pcm on pump gas...but it was an LS1 with a 427.
but still, stock pcm is good for it...just need an impedance converter.
Old Sep 12, 2004 | 07:59 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
IMO get a Vortech T or YSi trim. T Trim is rated for 825 crank hp.
Old Sep 12, 2004 | 08:57 PM
SJM Manufacturing Inc's Avatar
choose at least the D1 not D1SC, better step up ratio better low response. I think it is completly accessible, go with an aftermarket PCM though instead of trying to work around the stocker, you'll need it for low imp injectors anyways or converter box with stock computer.
Old Sep 13, 2004 | 11:58 AM
MEAN LT1's Avatar
After Market pcm isnt needed as they do make high imp 60lb and 72lb injectors. The high hp vette guys have been running them for a while now and they have report no idle problems what so ever. the only down fall to the big high imp injectors are the price. especially the 72's.
