FMIC Install Done
I have to go and double check everything this afternoon and ill do some testing and see how much boost i am seeing..... i kept the 3.7" blower pulley on there to see what the changes would be by just changing the IC.
On a side note i felt my IC thru one of my foglight holes (I havent cut out the front plate hole yet.. today) on the passenger side and it was kinda warm...... i felt the IC thru the drivers side foglight hole and it was really cold to the touch and it was 84 degrees out at 330am..... more to come.
Kyle
One thing I noticed on my truck is that I only have a small slit that air passes through to hit the IC and even taking off my lower air dam I only saw a 2deg drop overall. So I woulnd't worry about keeping the whole thing uncovered, just try to get semi even coverage
With my airdam on
what did you do on the ends of the hard piping to keep the rubber couplers from blowing off?
i had the same setup but every time got on it the hoses would pop off, so i just welded a bead around the edge to simulate a seam like on those fancy IC pipes you get from companies.
dirty what kind of clamps were you using and how much boost???
Kyle
J/K had to find something to pick on for ya.... Now come up here and help me out with my block!
another trick to use is to get some vise grips and make little bends , 3 or 4 , on the edge of the pipe. kinda like flaring it , but not all the way around the pipe so you could slide the hose over it. it sounds like back woods engineering but it works!
They feel tight as hell...... i had a hard time just trying to pull them off when i was test fitting them..... I will keep a eye on them ... thanks for the heads up.
Kyle
To do it properely, you would use a bead roller, but i have never seen one for sale cheap enough for a small project like this.
Ryan
Looks awesome. I told you that it would be cake. Now go get some results. Sorry I wasn't here for your call, i'm working 7 days a week (today was day 20 without a dayoff) I can't find anyone to fill this position so me and my other helper are really slaving lol......moneys great tho
Get some pics of the routing from the s/c to the FMIC. I take it you went to the pass side from the s/c and out to the top from the driverside?
Now lets get her to the track and get some testing done. 11's are getting old.
J
Get some vid up of how that BOV sounds
J
[img]
Ill post more later of the front clip on.
Kyle
