Broke a hole in Incon exhaust manifold > help
Dug and myself are installing a new steel block motor in his Incon twin turbo car.
We dropped the pass. side exhaust manifold/turbo assembly to the garage floor (long story how it happened).
Anyway, the O2 sensor in the pass. side manifold broke out of the manifold, leaving a perfectly round hole now where the o2 sensor used to reside. The actual theads in the manifold that the O2 sensor was screwed into are now attached to the broken off O2 sensor ... Leaving this 1" hole in the manifold.
I was suprised how thin the casting is in this area.
I feel the only way to fix this is to purchase an O2 sensor bung (who sells them?) and have it welded back in the manifold, and then install a new sensor.
My question is: Can this fairly thin cast iron manfold be welded? I have heard that cast iron does not weld very good.
This whole deal has been a real pain in the *** to say the least.
Dug can tell you about the [very deep laceration] he now has above his eye from an accident working on this car that happened just minutes prior to the Incon manifold being broken.
Yesterday was basically a nightmare as far as I'm concerned!
Ron,
Ron,
I would try to fix it with a sleeve before welding it. Ramchargers sells those weld-in bungs. I would try to turn the weld-in bung into a sleeve. that would mean you would have to drill and tap the manifold and run a die on the new bung (the are pretty thick so yo should be allright). If the bung from ramchargers doesn't work, take it to a good machine shop and they whould be able to make you a sleeve. If it was an NA manifld, I would say do a press fit with the bung, but not on a turbo car! There is defintiely no easy solution, though.
Did you have them coated or are they just bare? When I got my kit there were sheets of rust falling out of it so I had it coated.
-Geoff
-Geoff
Yup, deep laceration all right . . . I declined going to the hospital. I have been cleaning it regularly and dressing it, but one thing has not gone away overnight, now I really have to go get it checked out. My nose on the side of my face where the laceration is is completely numb. It feels like I got a shot of novacaine from the dentist. That can't be normal. I hope there is no nerve damage. I guess I'll find out soon enough!
Thanks for your help guys. Yesterday was a complete disaster![Sad](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_sad.gif)
- Dug
- Dug
Ron,
Ron,
Gary
Originally Posted by y2khawk
Did your manifold have the bung welded in to start? I don't remember which side it was, but the original casting had the boss for the sensor in the wrong place and the ended up moving it by welding in a bung in a different location.
On the other manfold (the short one on the drivers side), the O2 sensor is located in the end of the manifold very very close to where to turbo attaches to the manifold. The metal in this area is very thick.
I am not very happy at all with the overall design of this Incon turbo system. Not happy at all! ... I guess I'm just too spoiled from working on Turbo Buicks for a long time ... For a single turbo system, that is a very well engineered and designed system ... It's simple and works great! ... Of course, that ain't helping out Dug's problem much, now is it.
Ron,
Hey thanks Tom. Now that I know where you are I will ask if I need to! ![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Yea, I'm doing OK. Pics of the damage to ME are here:
http://home.earthlink.net/~dougboreland/laceration
- Dug
- Dug
![](https://ls1tech.com/forums/images/ranks/ls1tech20year.png)
That sucks. I'd have to make up a story about a bar fight or something. If you can't feel your nose, I would consider having it checked out professionally. Especially if you have medical coverage.
Post a pic of the damage to the manifold. You should be able to have it fixed by an experienced welder.
Well, if it fits back into place without any extra pieces, I'd say weld it back together. The key for cast iron is good Pre-heat, and really good post heat. You have to let that cast iron cool back down slowly! otherwise it will crack.
Yea, I did go to ER and have it checked. I smacked both nerve bundles above and below the eye, hence the numb nose. Yesterday it started tingling every few hours, I think it's coming back. Didn't break anything, but got a contusion.
I'll post a pic of the manifold up soon.
- Dug
- Dug
Here's a pic, I found a guy who would weld it, but he said he couldn't guarantee it because cast iron is quite difficult. Is it that difficult? Can I find someone who WILL guarantee it?
![](http://home.earthlink.net/~dougboreland/images/manifold.jpg)
- Dug
- Dug
hey Dug, a facial laceration gives one character.![Happy](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_stretch.gif)
Just preheat the manifold in an oven to 500' if it will fit. Weld it up, toss it back in the oven and let it cool back down slowly.
Otherwise just do a series of small welds letting it cool back down with each weld. Just take a little care to avoid cracks by welding it in evenly at first with some small tacks to avoid uneven stress. It only needs to be strong enough to handle exhaust backpressure so no need for a lot of weld deposit IMO.
This may be of a little help- http://www.lincolnelectric.com/knowl...ronpreheat.asp
Steve
Steve
see if your welder can get hold of some welco super missileweld welding rod. works real nice on cast. http://www.jwharris.com/images/pdf2/SMW.pdf
I was going to suggest this a few days ago. Find a company that does commercial tank fabrication, etc. You want a welder that is AWS and ASME certified for cast iron welding. They would not have any problems doing it. Probably will cost a little more but should get a lot better results. There should be plenty of those type companies in phoenix with all the aerospace, etc.
Gary
Gary
Guys, is there any reason I can't reuse the bung? I got it off the sensor, it obviously is a perfect fit for the hole
Can they just reweld it on? Why would I need a brand-new bung?
- Dug
![Winky](https://ls1tech.com/forums/images/smilies/LS1Tech/gr_wink.gif)
- Dug
the only problem i see is heat. that little piece of cast will probably crack or warp. super missileweld will fuse mild steel to cast. Being as thin as the casting is, I thinks you will only have one chance to fix it so get a qualified person to look at/do it.
If you really want to reuse the cast bung then you may want to consider brazing....
