How does everyone like there SDCE bracket?
. Everything bolts back up like the factory ATI stuff for the most part. Good luck....sounds like you have a badass ride when your done. Trending Topics
You should line up the altenator bracket and thread part of the rod in to the bottom hole wich is already there in a 6.0L iron block........ then go buy a Tap thast is 10mm by 1.5 thread pitch if i remember correctly..... call ATI real fast and ask them the thread pitch of the threaded rod that threads into it......... if u buy a good tap they say on the package what size drill bit to use..... I bought new threaded rod for mine...... works like a charm.... Mine works so good that while i was working on my FMIC i tied the belt out of the way and my ALT. pulley ate 2 ribs of my 8 rib belt and i used it again because i wanted to see if it would work and if with it missing ribs i still see the same boost........ Your going 8 rib correct..... i wouldnt go 6 rib..... the bigger 8 rib crank pulley realy helps out because you can run bigger blower pulleys and biger pulleys mean more contact patch and tha means lees or no slip.
Kyle
