382 Stroker with F1 procharger project
Old Sep 21, 2004 | 01:33 PM
slamar1's Avatar
Default 382 Stroker with F1 procharger project
Hi Guys!
New to the site and forum. Lots of good technical info here.
What size cam and injectors would you recommend? I have 60 lb injectors now.
Old Sep 21, 2004 | 01:46 PM
XtremeLover1999's Avatar
I have 75 lb/hr injectors and 242/248 dur , .6xx/.6xx lift , 114 lobe sep cam .
I haven't tried it yet . But will soon .
Geomar
Old Sep 21, 2004 | 01:50 PM
SINISTER's Avatar
Originally Posted by slamar1
Hi Guys!
welcome to the board sent u a pm
Old Sep 21, 2004 | 03:30 PM
BIGBOS's Avatar
I'll be getting my setup together soon
370 c.i.
236/242 .600/.605 114lsa
F1 blower
7.25" crank pulley, 3.4" blower pulley, SDCE tensioner setup (ONLY WAY TO GO)\
60lb injectors
Old Sep 21, 2004 | 04:47 PM
ls1290's Avatar
Dumb Ass Vette Moderator
On my 402/F-1R( 5.85" CP 4.10" BP ):
236/245//598/612//115 Comp Cam
75# Rc Engineering HI Injectors
Old Sep 21, 2004 | 05:36 PM
NA$TY-TA's Avatar
370ci
230/236 .598/.608 114+4
D1-SC
7.25" crank pulley, 3.4" blower pulley, SDCE tensioner setup (ONLY WAY TO GO 2nd that
60lb injectors
It depends on how much power you end up makeing you might have to step up to 72# injectors.
I would say with a 383ci go with a 236/242 .590ish/.610ish on a 114 or higher.... i would go with how your heads flow and hpw high you are going to spin the motor.
Kyle
Old Sep 22, 2004 | 08:09 AM
slamar1's Avatar
I will be using the AFR 225 heads. Will a 238/242 .598/.610 115 be too much cam? I would like a livable idle, nothing too radical.
Old Sep 22, 2004 | 09:03 AM
NA$TY-TA's Avatar
That cam should work just fine with a 383........
Old Sep 22, 2004 | 11:36 AM
ls1290's Avatar
The idle characteristics is mainly defined by the LSA. A 115 LSA will produce a nice slightly noticable lope.
Old Sep 22, 2004 | 12:24 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
Mine:
348ci
9:1
230/236//115//+2 Cam Motion from FMS
Vortech YS
83 lb Siemens
Old Jan 3, 2005 | 05:48 PM
slamar1's Avatar
Update:
Car is put back together. I got the car back from the tuner for a couple of weeks to break the motor in. Car made 724 at 6000rpm. Tq was at 647. There is more in it as we got a little belt slip at about 5000 rpm. The car has not yet been taken to 6500 so I am expecting a couple more lbs of boost. Maybe we'll see 800, but I am optimistic that I'll have 775. Final cam specs were .595/.598 232/234 114. Injectors were 72lbs. We'll find more in it... stay tuned.
Old Jan 3, 2005 | 06:24 PM
99.9percenter's Avatar
That is good!! What size pulleys? How much boost# @ 5000? 6000? At what point did you have to get bigger injectors? _Tim
Old Jan 3, 2005 | 07:32 PM
slamar1's Avatar
Thanks. This is with a 4.2 inch pulley
Boost:
2500rpm - 3lbs boost
3000rpm - 4lbs boost
4000rpm - 6.5lbs boost
5000rpm - 10lbs boost
at 5000rpms, the belt starts slipping a bit. but it looks like the following when we get it fixed:
5500rpms - 11-12lbs boost
6000rpms - 12-13lbs boost
6500rpms - 14-15lbs boost
We went bigger injectors from the get go. The fuel system is a custom job and the 72 lb injectors are at about 70% or so. This is with 2 fuel pumps and a boost-a-pump. Its pretty impressive... I will figure out how to post the dyno sheet so you can see... the fuel pressure keeps climbing with boost. It tracks it perfectly.
Old Jan 4, 2005 | 12:42 AM
slamar1's Avatar
Old Jan 4, 2005 | 01:44 AM
BIGBOS's Avatar
What belt tensioner setup are you using, and what kind of trans are you using
Old Jan 4, 2005 | 09:02 AM
slamar1's Avatar
I have the East Coast Supercharging bracket setup. Trans is a MN6. We were playing with different pulleys and come to find out, we discovered the Reichard racing pulley was turned backwards. The Reichards have grooves cut into them specifically for grip... intalled the wrong way and they can start chaffing the belt due to the cut design. An easy mistake and an easy fix. Final dyno numbers in a couple of weeks. Xtreme brought the car to me to put some "easy" miles on the motor before they really tear into it. The car is definitely wicked
Old Jan 4, 2005 | 10:51 AM
Birdie2000's Avatar
Wow, must have one monster of an exhaust port for that cam! Sweet power!
Old Jan 4, 2005 | 11:39 AM
slamar1's Avatar
Thanks. The heads are TEA stage 2.5 AFR heads with a 3.90 bore. Here is the flow sheet.
Old Jan 5, 2005 | 03:13 AM
2MuchRiceMakesMeSick's Avatar
very nice
Old Jan 10, 2005 | 12:44 PM
Worm's Avatar
Saw the thread on corvette forums, everything about this car is top notch. Very nice indeed.
