belt tension
Old Sep 23, 2004 | 12:24 AM
WS-6_2002's Avatar
Default belt tension
I have an ATI kit and not sure how tight to make the belt. Any suggestions?
Old Sep 23, 2004 | 01:41 AM
1dirtyZ's Avatar
real tight
seriously, i had my 8 rib so tight that it would ring or humm when you tap it with your finger.
i run an sdce tensioner kit now and i'm alot more satisfied with it than i ever was with the stock ati crap. and the cool thing is the belt tension is no where near as much as what it was before and i get better results.
another thing to remeber is that if you are using a new belt , it will stretch and you will have to retighten it every now and then till it "settles".
Old Sep 23, 2004 | 08:44 AM
BIGBOS's Avatar
With the "stock" 8 rib stuff, I had it as tight as it would go.....
With the SDCE stuff I would run under the reccomended amount and still have no slip
Old Sep 23, 2004 | 09:28 AM
NA$TY-TA's Avatar
Grab the belt with your pointer finger and your thumb..... try and twist the belt...... if you can twist it more then 90 degree's its to loose.... You shouldnt have to big of a problem with the stock ATI 8 Rib stuff..... 5 litre eater is doing fine... PM him.
Kyle
Old Sep 24, 2004 | 02:10 AM
WS-6_2002's Avatar
Sorry to disappoint you guys but I have the old 6 rib. Do the same theories apply?
Old Sep 24, 2004 | 05:30 AM
ls1 1990 VN's Avatar
sorry to hi-jack, it,s been mentioned before that sdce tensioner is good, looking at the mtr from front of car is the tensioner mounted on the left, are your blowers on the left. can this tensioner be used if blower is on the right.
RH drive Holden.
Old Sep 24, 2004 | 11:35 AM
NA$TY-TA's Avatar
How i mentioned with measuring it with your fingers is how i did it with my 6 rib setup but i could never get it from slipping...... I would upgrade to a spring tensioner setup from SDCE for 6 rib setups.. or step up to the 8 rib spring tensioned setup.........
For the Aussie..... heres a few pics of mine on the car with out the radiator in... i dont know if you can get it to work on yours but i hope these pics help one way or another.
Kyle
Old Sep 24, 2004 | 02:47 PM
thanks NA$TY-TA. just for the record calling a kiwi an aussie is like calling an america a canadian, Better get back on topic.
Old Sep 24, 2004 | 10:17 PM
WS-6_2002's Avatar
Nice pics. What is the cost of the tensioner and where can I get one?
Old Sep 25, 2004 | 02:02 AM
NA$TY-TA's Avatar
Sorry man......... i should of looked at your place of orgin... i just took it as you have a Holden that u live in Australia..... if i knew u were from NZ i would of known to call u a Kiwi...... Ive been to both and loved them both that i wanto come back there............. if u need more pics i have them on my site....
itlxlr8.homestead.com
Kyle
Old Sep 25, 2004 | 02:05 AM
NA$TY-TA's Avatar
Milillani huh???? I used to live there........... Do you know Dave (Diesel)..?? I see you have a few things done to the care so u wont be scared of the $$$ the kit......SDCE makes it.... they are not a sponsor so PM me and i can get ya the link. The kit works awsome and lots of us here on the board use it. Do you frequent the local EFIUNLIMITED.com board??? im NA$TY-TA on there also........
Laterz
Kyle
Old Sep 25, 2004 | 04:08 AM
1dirtyZ's Avatar
i'll attest to how well the sdce tensioner kit works!
Old Sep 25, 2004 | 09:57 AM
NA$TY-TA's Avatar
Stop using such big words.... we are sapposed to be car people...........
Kyle
Old Sep 25, 2004 | 10:53 AM
1dirtyZ's Avatar
LOOOL! i'm trying to sound sofistucated
Old Sep 25, 2004 | 02:09 PM
NA$TY-TA's Avatar
i would try but id probably screw that up and sound even dumber....
Kyle
Old Sep 25, 2004 | 05:18 PM
WS-6_2002's Avatar
You got it. Mililani. I don't know Dave. I am very interested in the tensioner. I hardly go to EFI. I'll pm you. Thanks guys
