Is it wise to do this?
Old Sep 24, 2004 | 03:28 AM
LSs1Power's Avatar
Default Is it wise to do this?
I was planning to run 8psi on cammed LS1 (stock bottom end), but after seeing the Water/Alky injection it got me thinking into running 11-12psi with the Water/Alky injections coming in after 8psi to keep things safe. Rob did run 14psi on stock bottom end with a TURBO which is harder on the engine since full boost hits early in the RPM. Do u guys think i will get away with it for at least one year until i built the engine? Also at what RPM i should pass 8psi if i pullied the SC for 12psi with a D-1SC?
Old Sep 24, 2004 | 01:13 PM
LS1Bird's Avatar
Do I think you'd get away with it for a year - doubtful if you are driving it much, or driving it hard. I've always considered 8 pounds on a stock bottom end to be the last safe boost amount. I'm not a big fan of the alky injection either, and wish I had $100 for every friend of mine that tried it only to go back to IC.
Mike M
Old Sep 24, 2004 | 01:40 PM
goober35's Avatar
The turbo is way easyer on the motor than the SC. Even at idle you have some boost. On a turbo you have none. At 12psi i would say the motor would last 1-3 mouths tops. If you drive it every day maby a mouth if you drive it 10miles a week. It might last all year. 12psi is a lot of boost and alot of power. It will rip apart any unbuilt motor. Run a search on here. I know i have seen pics of stock bottom ends letting go at 8 psi. Lets just say you will end up spending more money than you should.
Old Sep 24, 2004 | 02:02 PM
y2khawk's Avatar
I ran my old Incon kit on a STOCK motor, never even pulled the valve covers. 24K miles boosted (14k before the turbos went on), 600RWHP/600RWTQ. 9 psi on pump gas (93 octane), 14 psi (100 octane). 128MPH and dipped into the 10's w/ the 6 speed. When i built the motor, the only obvious thing was greater than expected ring wear for a 38K mile motor.
If you can fuel it, it will live.
Old Sep 24, 2004 | 02:40 PM
ChevyNo1's Avatar
Mine lived for a very short time on 621/685 . . . that was running water/alky. But I think it was just as simple as too much powah for the stock motor. This was on 91 octane and 12psi!!
I am selling my SMC kit if you are interested . . . looking for $275 shipped. Nothing at all wrong with it, I have a new motor I'm dropping in and I just don't need it anymore. Enough braided line to do trunk mount, which is what mine is. Comes with three jets: 7, 10, 15gph. Still in the car but can have it out and on it's way PM me if interested.
- Dug
Old Sep 24, 2004 | 04:48 PM
LSs1Power's Avatar
So from what Im sensing here i shouldnt do it. Also i think Turbo is harder on the engine because u get the 12psi at 3500 RPM instead of redline peak for less than a sec. I know SC put strain on the crank, but i was talking about abuse on the pistons and rings. So the case here is too much cylinder pressure for the stock pistons and rings right? I was thinking 12psi with water/alky + 11.1 AF to keep things safe, but if the cylinder pressure is what going to kill my engine then its not worth it i guess. Anyone out there did run more than 10psi on stock engine for a while please share your experince?
Old Sep 24, 2004 | 04:51 PM
LSs1Power's Avatar
- Dug
I could be intrested, but I have some stuff to finish first before i get the injection system. I have to install the SC and install the 8.8 rear end when Craig send it to me (I hope in this lifetime). I will send u a PM when im ready to buy it. Thanks.
Old Sep 26, 2004 | 02:10 PM
ChevyNo1's Avatar
Will do. I very well may still have it!
- Dug
Old Sep 26, 2004 | 02:26 PM
F8L Z71's Avatar
12 Second Truck Club
You can do it with Alky alone but I would highly recomend the IC first. I run both and am having great results with them but if I had to choose one it would be the IC.
As for 12psi on a 5.7L? I doubt it would last long. That's a lot of power on that motor. On a low compresison truck motor though.... I'm ok so far. LOL
Old Sep 26, 2004 | 02:32 PM
T/A Medic's Avatar
Last just about as long as that 4L60e u have muahaha
I think the 4L60E was made/designed by disgruntled autoworkers!
Old Sep 26, 2004 | 02:35 PM
F8L Z71's Avatar
HATER!
Hahaha yeah, I agree though. The desginers must have taken a pay cut the day before they drew up plans for this POS!
Old Sep 26, 2004 | 02:50 PM
goober35's Avatar
Stock motor 12psi of boost. Stock tranny (4l60e). Stock rear end and drive shaft.
There is a really really good chance something is going to break
Old Sep 26, 2004 | 04:14 PM
T/A Medic's Avatar
hell yah im hating... I aint skeerd to admit it! ur freakin truck is second faster than my TA ... what kind of BS is that !
