Intake temp ????'s
Old Sep 24, 2004 | 09:37 AM
blue-ss-camaro's Avatar
Default Intake temp ????'s
how do you guys measure your intake temps?? I would like to see what mine are to see if I can turn up the boost since i'm so rich.
Old Sep 24, 2004 | 09:54 AM
F8L Z71's Avatar
12 Second Truck Club
Just use ATAP, EFILive, HP Tuners etc.
If you are talking about after spraying methanol then you're stuck like I am till you add another sensor after the meth injection.
At 5psi of boost without any meth or IC you are probably between 130-150deg IATs after a full run.
Old Sep 24, 2004 | 10:12 AM
slow's Avatar
you will need to remove the iat timing tricker you have, and wire up the iat/act sensor to measure the incoming air temps to the TB.
Ryan
Old Sep 24, 2004 | 05:23 PM
gametech's Avatar
Active Streak: 30 Days
Active Streak: 60 Days
Where would be a good place to find an aftermarket IAT sensor? I need to measure after the MAF.
Old Sep 24, 2004 | 08:33 PM
LSs1Power's Avatar
Default SP Intercooler Temperature Meter
This would be the perfect device for u guys who wants to mesure before and after IAT. This device will also show u the difference in TEMP. U can buy it from here http://www.sp-power.com/newproducts.htm
Old Sep 24, 2004 | 10:39 PM
01SCSS's Avatar
I have an Autometer 2 channel intake temp gauge, it has two probes and a button on the controller to switch between the two. I have mine before and after the Intercoolers. On a hot 90 deg day precooler temps are like 170 and after the Intercoolers its about 100. In the winter the temps are like 150, and 70 deg.
Autometer PN 4373
