SDCE on the way
for the record, i have an F1-r not an F1 on the car. i'm currently running the 3.7 pulley and seeing all the boost i can handle if not more
kyle, check your pm's
[IMG]C:\Documents and Settings\Peter\My Documents\My Pictures[/IMG]
Mike?
Yes it is sapposed to be that way..... it rides in the middle of the belt.............. i called you.... check your voice mails.......................
Kyle
I think it slipped off 90mm pulley. Back to spending more money.Even though I'm not to happy right now > I'm sure after all is done I will be.
I am not making fun of you or giving you a hard time. I want you to get this set up working as it kicks ***. Go over everything again, print out kyles pics and use them as a reference. I had some good clear pics of mine but I no longer host them as I am using the space for other pics and vids. You will get it figured out.
J
I would post some pics so this could make more sense > how do I do that?
When I said this sucks > I didn't mean SDCE sucks > I ment "this" sucks (my situation) I want boost and I want it bad!!!!!
To post a pic, just attach it to your post. Go to the "Go advanced" button on the lower right hand corner, then you will see a section in there that says "manage attachments" or something like that. Click on that and you will be able to upload pics from your computer to tech. You might have to resize them with your photo editing program(I use photoshop) because they have a file size limit of 100kb.
Yeah my directions were pretty shabby, but I was able to figure it out....just takes some head scratching. Looking up at the assembly from the bottom from the crank pulley the the s/c pulley you will be able to see the belt out of alignment, you can do this from the top too. The belt will look crooked. As for the spacers go back to two thick ones per stand off and see where that gets you. It worked for me best. But you can always try two thick and a thin one per stand off to see what happens too.
Also on the s/c itself there is a washer(thin rust colored one) under the s/c pulley itself, did you remove this one? I left mine on.
Its a lot of trial and error especially with something like this. SDCE is has excellent service, too bad its the weekend
I am sure they would have got you on the road already. You are close tho, and big no slip boost is right there....just a few more tweaks.J
Kyle
Call if needed.... can you get another belt local or do u have to order it???
Kyle
Working for Hooters is good > but I travel tons!!!!
