SDCE on the way
Any tips for for putting this bad boy on? I can't wait > I have had my P1SC for almost 2 years now and finally I will see some boost!!!!!!!!!
Mike
Kyle
I'm so excited that I'll finally get my blower to kick some ***! 2 years is a long time to wait for something to work right!
Make sure you follow the directions and the belt has to go thru one brackets like in that last pic..... if you dont get directions by chance PM me and and PM you my cell number and i can walk you thru it like i did BOS...
Ill se if i can dig up some more pics...Kyle
Mike
Kyle
Thanks
does this SCDE stuff, solve the belt slip problem? is it an entire kit to convert to 8 rib? or does it still use the 6 rib? and are yall getting by with the stock bracket or still afterkmarketo ones?
and about how much does this cost? if someone were to buy a D1 kit used, what would be needed to make it crank out about 15psi?
thanks
ed
firebird455@onebox.com
Yes Yes Yes the SDCE kit DOES stop the belt slip problem..... There is a kit to convert your stock rib setup to a spring tensioner, but i didnt want to do that i wanted a 8 rib setup for pushing the system harder down the line.... I am using a aftermarket STEEL bracket ($200), but alot of people are using there one that came with the kit.... you have to send your bracket is so Scott @SCDE can modify it. I believe it $700 for the 8 rib spring tensioner setup.... alot of us got in it when they had a GP going on.... who knows maybe you can start another one...... If you were trying to reach 15psi 8 rib is the only way to go.... PM BOS he had another 8 rib setup before and a cog setup and couldnt get either work..... now he has the SDCE 8 rib setup like me and FRCEFED and we are all very happy with it... its one of the best if not the best blower mod i have done yet.....
Kyle
thanks
ed
Yep... thatll do it....
Kyle
