Seeing 7lbsof boost from a 5lb sts kit
Old Oct 6, 2004 | 04:00 PM
blue-ss-camaro's Avatar
Default Seeing 7lbsof boost from a 5lb sts kit
Why would I be see 7lbs?? My a/f is ok..its at .92 on the a/f gauge. I dont want to hurt anything by running it like this. the car is crazy. broke the tires lose in third gear went the boost hit. the weather here is only about 60 degrees could this be why I am seeing 7lbs??? I just dont want my iat's to get to high....
Old Oct 6, 2004 | 04:08 PM
SSnakekiller's Avatar
DO NOT BOOST any more! Something is up with your wastegate or some other factor. Do yourself a big favor and lay off the boost until you resolve it. Untuned, with stock injectors, and with no methanol, 7psi spells trouble. Contact the dealer you purchased the kit from to sort out the problem.
Actually, if you have a boost controller hooked up, take it off and just run the one vacuum line.
PurEvl's Avatar
I know I see 2-3 more psi with SC when its colder out, you dont a have boost controller you can just turn down?
Old Oct 6, 2004 | 04:18 PM
It is tuned... I have a tune by nelson performance... I am super rich. did you not see the a/f numbers. I really think its cause it is so cold out.
Old Oct 6, 2004 | 04:27 PM
What are you using to read your AFR? Sounds like you are trying to say your 02 sensors are reading 920mv....is that right? Are you using Autotap?
If you are reading 920mv, that is not running rich. You actually want it in the mid 900's, around 950 for a conservative tune.
Old Oct 6, 2004 | 04:57 PM
I was using a wideband to read them and the a/f gauge and when I was reading 9.9 on the wideband the a/f gauge read .93 mv that was with a innovative wideband gauge. I also have midlenth headers if that makes a difference. I also do not have a boost controller on the car. I call my dealer and he thinks that its cause its so sool out also. he is calling someone to make sure though. maybe I had the wideband in the wrong part on the y pipe. could this be possible??
Old Oct 6, 2004 | 05:14 PM
Blackbird's Avatar
As far as I know a wastegate will hold the boost at a certain level no matter if it's cold or hot.
either it's not seeing good signal, the spring is wrong, wastegate is broken somehow, etc....
I could be wrong on this but I am 99% sure weather will NOT effect boost levels on a turbo car.
Old Oct 6, 2004 | 05:16 PM
CHRISPY's Avatar
weather will not affect max boost in a turbo car provided the wastegate is correct. I wouldn't hammer on the car till you figure it out
Old Oct 6, 2004 | 05:55 PM
Armageddon's Avatar
...with cheese.
I def say wastegate too... maybe a bad wastegate or doesn the spring inside of it have something to do with it too? I thought you could tune the wastegate to sit at whatever initial pressure you wanted.. well whatever the issue im pretty sure its the wastegate
Old Oct 6, 2004 | 06:06 PM
MIGHTYMOUSE's Avatar
if you have injectors/tune and are conservative on the timing i would leave it.. 7 is not dangerous.. on a stock motor.. 10 would be
Old Oct 6, 2004 | 06:15 PM
Slowhawk's Avatar
LS1Tech Sponsor
I agree,turn down the controller.7lbs is dangerous on the STS with no intercooler or meth. . The intake temp shoot's to over 170 degree's fairly quickly.
.92 on my EFI live ='s 12.8-1 on my wideband,way too lean for a FI car.
Old Oct 6, 2004 | 08:20 PM
DaveSchott's Avatar
Don't discount the possibility that your boost gauge is wrong. Best way to verify is to do a dyno session at a shop that has a calibrated psi gauge and compare yours.
That said, cold air does make a difference.
Old Oct 6, 2004 | 08:57 PM
what about IAT's??????
Old Oct 6, 2004 | 10:59 PM
trtturbo's Avatar
Chad, did you get anything figured out? Was the line for boost reference okay?
Old Oct 6, 2004 | 11:00 PM
Ooooh OK, 9's AFR, yes ur running FAT!!! If you have checked all the stuff around the wastegate and are sure it is good, then you may want to check that your maf is functioning properly. I cant see how you are boosting 7psi with 9's AFR with a tune on stock injectors right? Could be something MAF related.
Also take apart the wastegate and check that the diaphragm is not pinched and make sure the spring and everything lines up correctly.
If all this fails, you may want to just get a 3psi spring for now, which will probably put you in the 5psi range considering what the 5psi spring is doing.
Now how nice am I to help out when we didn't even sell you the kit
Old Oct 6, 2004 | 11:14 PM
trtturbo's Avatar
He hasnt had the wastegate apart or off. It was doing fine, then started to show more boost. Rick only suggested the boost reference line could be pinched or the brass elbow could be screwed in far enough to possible interfere with the air flow. Really havent seen any issues with the Tial wastegates. Everyonce in a while I will
see 6psi, but it usually is right on.
Chad, you might also put another vacume/boost gauge on to check and see if the gauge is reading properly.
Old Oct 6, 2004 | 11:24 PM
F8L Z71's Avatar
12 Second Truck Club
On my kit without the FMIC I would see 6psi everytime I went WOT. Didn't matter what the outside temp was. Now with the FMIC I am seeing about 4-5psi with the original spring. Sometimes I'll spike to almost 7psi but it is usually near a shift point.
Old Oct 7, 2004 | 08:16 AM
I am going to check out the wastegate today to make sure all is in order. I will try to get ahold of another boost gauge to see if it is the gauge. is there anyway that it could be the intake pipeing cause I blew One off by the MAF and after I put it back together I got 7lbs. also I could be rich cause I descreened the MAF. thanks for all the help guys......
Old Oct 7, 2004 | 08:55 AM
CHRISPY's Avatar
that is normal with an intercooler and the density of air changes
Old Oct 7, 2004 | 09:53 AM
Talked to a few guy's up here that have turbo cars and they all have seen a gain of 2lbs when it is cold out. So I am guessing that the cold air makes a difference. What are the lowest temps you guys see??? It has been in the 50's to 60's here for a high....I would think the densor air would change things......
