STS before/after dyno w/ 5 lbs boost
I know F8L can build 5-7psi at the light brake loading.
It makes for quite the launch in a 4x4
As for the filter placement, they provide a drycharger and if your really worried fabbing up a shield for the filter would be super easy.
Definetly NOT a reason not to buy a kit IMO.
I can easily build boost by brake stalling it. Once I hit 7psi and above the truck can't be held back through and it will start to roll forward. Launching at 6-7psi is good for 1.80-1.83 60's. I am working on keeping the truck steady so I can launch at 8psi or more
If I launch off idle with this big turbo I can only get 2.1 60's.. It's tough moving 5100lbs of beef that quick. LOL8psi launch (2.0 60'), then 6psi launch (1.84 60')
http://my.starstream.net/f8lpony/Jus...0-%20Small.WMV
My kit is kinda wacked since my turbo is way too big for my size motor (5.3L w/ GT67 and .81 housing) but even so I spool up pretty decent but lag is very evident. With the GT35 I hit full boost right about 3800rpm or so going from an off idle dig. I have a 3000stall (based on a stock motor) in the truck though and with that kind of TQ it is probably more like a 3500stall so boost came on hard and fast with that setup.. It just lacked the top end I wanted and I knew I'd be doing a 6.0L soon and the GT35 would be too small...
Your truck runs real good and I'm sure gives most Lightnings fits.
We'd all like to see more times from the STS enhanced LS1 F-bodies out there. The dyno graphs are cool but we need more ETs.
Now I can get it to 6psi VERY quickly if I just mash the gas pedal. In the video I am slowly applying the gas and as it gets close to 5psi I got annoyed and started to floor it. I waste a good 3seconds just getting it to 1psi because I was so hesitant to just floor it. Not anymore
I hear ya though. Everyone knows what they can do on trucks so it's natural to want to see what it'll do on the F-bods considering over 3/4 of the people in this forum own cars.
Paul
I look forward to hearing more progress from you guys(and gals).
I think with my SS4000 stall ,boost off the line would not be an issue.
I would love to drop my Nitrous shot down to like a 30 shot and add the STS kit. Keep the info coming,Thanks again.
Dave
-Geoff
-Geoff
We did leave the stock TC in there and it's perfect for the street but at the track it needs a little help to build boost quicker for better 60' times.
Paul
No becasue this is a 100% daily driven street car so messing around with the brakes is not an option. It will run at the track just like it drives on the street.
Paul
