Better cam for d1sc.
Old Oct 12, 2004 | 02:32 PM
badeSST's Avatar
Default Better cam for d1sc.
232/236 .575/.578 114lsa
224/227 .563/.569 114 lsa
Just wondering which cam would be better in your guys opinion. I know the top one is bigger but which do you guys think would be best.
Old Oct 12, 2004 | 03:22 PM
ls1290's Avatar
Dumb Ass Vette Moderator
Depends on the CID of your motor. For stock, I would go with the 224/227 .563/.569 114 lsa, but on a 115 LSA
Old Oct 12, 2004 | 03:41 PM
PurEvl's Avatar
I run 230/232 598/602 at 114
Old Oct 12, 2004 | 03:49 PM
badeSST's Avatar
I have a stock motor, I just want the cam that will make my car run the best.
Old Oct 12, 2004 | 04:11 PM
PurEvl's Avatar
mines stock cubes, just forged internals, if you have a good tuner its not hard to get it right
Old Oct 12, 2004 | 05:18 PM
badeSST's Avatar
So you think i should go with the bigger one?
Old Oct 12, 2004 | 05:27 PM
Pro Stock John's Avatar
LS1Tech Co-Founder
Community Influencer
I run FMS/Cam Motion 230/236//115/+2.
Duration makes power, but your power peak might (potentially) be kind of high with the 232 cam. How how do you plan to shift?
Old Oct 12, 2004 | 06:06 PM
PurEvl's Avatar
actually im a moron. johns right, I rev to 7k due to the built motor, This cam needs revs and boost. Sorry about that. Listen to the others
Old Oct 12, 2004 | 06:25 PM
NA$TY-TA's Avatar
Why those 2 cams??????
For a stock cube motr i woulndt go over 230 on the exhaust....... so a
224/230 with .570ish lft and .580ish on the exhaust and on a 114LSA so not to bleed off any boost and you will probably shift around 62-6400 rpm's.....
Kyle
Old Oct 12, 2004 | 06:31 PM
badeSST's Avatar
well the second one is one that thunder sells, I have talked to some people who said this is a sweet blower cam. Im new to this whole game so I want to have the right combo. I guess id shift at around 62-6300 Id have to see where my powerband is after i get it tuned. Any suggestions would be greatly appreciated.
Old Oct 12, 2004 | 06:56 PM
NA$TY-TA's Avatar
This is from Speed Inc's site......>>>>>>>>>>
Speed Inc Blower Street Grinds 346-408ci
Cam Duration Lift LSA
int. exh. int. exh.
SC1 224 232 .581 .595 114
SC2 226 234 .598 .599 117
Old Oct 12, 2004 | 07:03 PM
MelloYellow's Avatar
That one.
Old Oct 12, 2004 | 08:28 PM
badeSST's Avatar
Ya I think that is prolly the one I'll end up going with.
Old Oct 13, 2004 | 11:29 AM
LS1Tech Co-Founder
I think that 232 cam would need to be shifted quite a bit higher than 6200 to justify running it. I shifted mine at 7100. I made peak hp at 6900 when they left off on the dyno (746rwhp).
Old Oct 13, 2004 | 12:03 PM
PurEvl's Avatar
my rev limiter is 6800 and my power hits it like a brick wall, I could go right to 7400 im sure
Old Oct 13, 2004 | 03:48 PM
NA$TY-TA's Avatar
With my 230/236 my rev limiter is 7000 and i pull to 6600.... that 232 cam would be to big for you........ I would go with another cam then the 224/227.... you can call Allen at FMS and get a custom cam ground for the same price.
Thats just my .02 though
Old Oct 13, 2004 | 05:02 PM
badeSST's Avatar
maybe ill get ahold of him, i hear he makes some sick *** cams. Should I just tell him all my mods and ask him what would work best?
Old Oct 13, 2004 | 09:22 PM
NA$TY-TA's Avatar
Yeah just call and talk to Allen. Tell him everything you have doen and what all you want to do with the car and he will help you out.
Kyle
Old Oct 13, 2004 | 09:51 PM
badeSST's Avatar
I appriciate it Kyle, I went ahead and emailed him, it's really hard for me to call people because i'm in the desert and it's 8 hours ahead over here.
Old Oct 13, 2004 | 09:52 PM
NA$TY-TA's Avatar
Deployed i take it........ Ive been there brother... I was there when it started..... Thanks god im on shore duty now......
Kyle
