boost question
Old Oct 20, 2004 | 04:32 PM
gen 3 bu's Avatar
Default boost question
they are sayin on the sts kit that they are pushin 8lbs of boost with methanol on a completly stock motor. my compression is going to be 9.31... how much more boost do you think i will be able to push and still be safe.
i have:
3.905 diamond pistons
6.125 scat rods
stock crank
stock heads
weiand aluminum intake
Old Oct 20, 2004 | 04:50 PM
MECHAM's Avatar
need to know...
your pump gas octane?
altitude?
max timing?
Old Oct 20, 2004 | 04:54 PM
F8L Z71's Avatar
12 Second Truck Club
Lots of variables there but I think your problem isn't going to be the motor. It's gonna be IAT cooling and fuel...
I'm assuming you have a fuel system so the cooling part is gonna give you trouble.
Methanol is great up to a point but I don't see how anyone could run high boost (14+psi) with just the meth unless their turbo is incredibly efficient and they are under 200deg IATs before the meth... At 13psi I was hitting 200-230deg IATs in my truck before meth and the FMIC..
IMO if you wann amake serisou HP then I would add a FMIC or IC and Meth. That's what I did/am doing.
Old Oct 20, 2004 | 08:32 PM
gen 3 bu's Avatar
it is actually a 1994 3.4 camaro w/ an ls1 swap. the local alt is @900 ft above sea level. max pump gas is 94 sunoco. it probably get the upgraded turbo right off the bat from sts and a re-tuned pcm to match it. with a 2002 ls6 cam.
what is a safe boost level w/o meth and /or intercooler
Old Oct 20, 2004 | 08:34 PM
F8L Z71's Avatar
Without the IC or Meth I would say 6psi or so depending on your tune.. IATs go up VERY fast after that point... I was seeing 130-150deg IATs ar 6psi and 190deg IATs at 10psi.
Obviously my setup is different but you'll probably be within 20deg of those marks.
Old Oct 21, 2004 | 12:26 PM
gen 3 bu's Avatar
out of the box the sts kit is setup for 5 psi for stock compression
this will have almost 1 point less @ 9.3:1 - stock is @ 10.1:1
how much more boost can it handle?
Old Oct 23, 2004 | 05:56 PM
gen 3 bu's Avatar
bump!
