a/r ratio for remote mounts
Old Oct 23, 2004 | 06:05 PM
gen 3 bu's Avatar
Default a/r ratio for remote mounts
i am trying to find a good a/r ratio for a twin turbo remote mount setup.
it will be a 347 cid al block, 9:1 cr, arp studs everywhere, single plane 4 barrel intake (blow-thru carb or mfi converted), possibly afr heads, possibly 2002 ls6 cam, long tube headers, 3 inch dual exhaust with dr. gas x-pipe to turbos.
as crazy as it sounds, i actually want a little lag so it wont blow the tires off on the street. spool @ 3000-3500 rpmin a 2800 pound car with a 50/50 f/r weight ratio. i want to hit the converter before it sees boost.
all suggestions are welcomed
kevin
Old Oct 23, 2004 | 06:16 PM
MIGHTYMOUSE's Avatar
i figure since the gasses are cooler way back there the a/r can be choked down some.
sounds like a perfect place for my gt-80r to go.. happens to be for sale. .96 a/r
pics in sig pm me if interested or hit the for sale post
Old Oct 24, 2004 | 02:09 PM
gen 3 bu's Avatar
more specs?
how many do you have?
Old Oct 24, 2004 | 10:19 PM
twin 80s would be rediculous.. i have one.. you only need one trust me
Old Oct 25, 2004 | 10:49 AM
gen 3 bu's Avatar
what is the power potential on a 347 w/ twins?
what did it make with one?
Old Oct 25, 2004 | 11:24 AM
PurEvl's Avatar
I agree with that, two would be unthinkable
Old Oct 25, 2004 | 03:43 PM
check your pm. i ade 775 at 17psi with my 346ci(9:1) and 836 at 20psi on a 366ci(8.4)
power potential with twin 80's would be over 1700rwhp i imagine
Old Oct 25, 2004 | 05:52 PM
gen 3 bu's Avatar
just what i am looking for - get 20+ mpg and runs 7's in a 2800 pound car
Old Oct 29, 2004 | 06:38 PM
gen 3 bu's Avatar
is that flywheel or rear wheel hp
kevin
Old Oct 29, 2004 | 06:41 PM
PurEvl's Avatar
kevin
no one posts crank HP around here, his car is disgusting fast. Makes mine look like a neon and thats not easy to do
Old Oct 29, 2004 | 06:44 PM
gen 3 bu's Avatar
what would 775 run in a 2800 pound car
Old Oct 29, 2004 | 06:47 PM
PurEvl's Avatar
jesus I wouldnt want to know, high 8 low 9 maybe? I know hes high 9 at 3700ish I think
Old Oct 29, 2004 | 08:52 PM
gen 3 bu's Avatar
would it be safe to go 23 psi, fmic and 150 shot?
i want a streetable 1000rwhp on pump gas with 346cid
