ALMOST hit 10s today....almost
Old Oct 23, 2004 | 09:41 PM
DarkFormula's Avatar
Default ALMOST hit 10s today....almost
I'm in Houston for business through the 28th, so my brother drove my car today at our COFBA Norwalk Day. He reported a best of 11.17@125 w/ 1.66 60' on 275/50/15 BFG DRs (15psi of tire pressure). What sucks is that the next pass, he cut a 1.62 60' (10s for sure), but my ATI idler pulley torqued and bent it's retaining washer, thus killing my belt tension. It ran a 11.4x@120 that pass, and we called it a day. It's a 10 minute swap for a $.50 washer, but I overlooked that when I packed my tools and replacement parts in the car before I left. This is the 3rd washer I've bent in a month. I guess it's time to have a machine shop cut a slightly thicker one, or maybe move to that SD? tensioner setup.
Anyways, I'm very happy with the car's performance and am very grateful my brother was able to take it up there in my absence. He claims to have enjoyed driving it, even if it is RWD (he has a GTP that runs mid-11s at 116ish)
So, 11.17@125 is this year's best. 10s were there, but got owned by a simple fender washer. Oh well, not too bad for a full street car with full interior, AC, stereo, and tuned for 94 octane pump gas
Mods in sig. Also, this was a consistant 12psi on a 5-rib Polycog belt. Last time I put the belt on, I accidentally left a rib over the crank pulley and it got chewed off. But it was making 12psi on the dyno last week, so I left it on since it was working. It stayed put
Old Oct 23, 2004 | 10:12 PM
LordFlux's Avatar
"I guess it's time to have a machine shop cut a slightly thicker one"
I was thinking about that just earlier today. We had to really crank down on the tensioner to keep the belt from slipping... and this is with an 8-rib! After the final turn on the tensioner bolt, I saw that the idler pulley looked a little lopsided. It's been fine so far and did okay on the dyno, but I'd feel better if I had a thicker washer on there.
Old Oct 23, 2004 | 10:29 PM
Damned washer
Nice car, Flux. Its very clean and sounds like it can back it's **** up
http://www.cardomain.com/memberpage/479288 is my Car Domain page.
Old Oct 23, 2004 | 10:41 PM
LordFlux's Avatar
Thanks, man. Congrats on almost hitting 10s. That's insane!
Old Oct 23, 2004 | 11:34 PM
AustinL911's Avatar
If Chris would have taken out those seat covers...you'd probably have had your 10 sec. slip
Old Oct 23, 2004 | 11:36 PM
Hey, leave my lightning bolt seat covers outta this
Old Oct 24, 2004 | 07:25 AM
BlwnTA's Avatar
7 Second Club
Congrats Anthony...glad to see the MMS and RR 3.5 I sold you last year is doing the job. Do you still have a 10 bolt?
Mark
Old Oct 24, 2004 | 09:05 AM
Got Me SOM's Avatar
12 lbs on stock bottom end, aren't you a little worried about that? what is your car's weight?
Old Oct 24, 2004 | 09:33 AM
kp's Avatar
kp
I had a friend make a nice 1/8" steel washer with a small groove that fit the slot, before I did that the pulley would rub the bracket when making a pass. That thin little washer is pretty sucky - congrats on the times.
Old Oct 24, 2004 | 09:36 AM
Mark, they're working perfectly. Yes, I have the 10 bolt still, but it's been beefed up with a TA girdle, Zexel-Torsen HD posi, and GM gears. Been cutting 1.6-1.7 60; for a couple of years now with that setup. I do plan on a 9" in the next year however. I'd like to see some 60' on the 1.4 range
Got Me SOM, not at this point. The A/F is stuck at 10:1, and I'd added a few gallons of 100 octane to be on the safe side of things. Not to mention, Mike Brown was able to hit 9s with a turbo on the stock bottom end for awhile. The tune is good, so I have really no reservations on it's durability. The car weighs 3340 with a half-tank and no driver.
Hopefully this winter will be seeing the 427 going in. We'll have to see
Old Oct 24, 2004 | 09:39 AM
Thanks kp
Do you still have this friend available? I'd be interested to see how much they'd charge to make me one. If you could check into it, I'd greatly appreciate it!
Old Oct 24, 2004 | 09:49 AM
kp's Avatar
kp
He has his own machine ship and made it in a few minutes but I doubt he will do another, kind of hard to get him to do anything most of the time
It was just a washer the same size as the ATI one but it was way thicker, also had a small (~.020) raised part that fit snug in the groove. Problem is once you get it not to move it will start eating idler bearings so stock up
Old Oct 24, 2004 | 11:13 AM
Chris@AP-Engineering's Avatar
Under criminal investigation for fraud
Congrat's!! Keep trying, you should be able to get her in the 10's
Old Oct 24, 2004 | 01:38 PM
LordFlux's Avatar
Sounds like an awesome washer, kp. Do you happen to remember the width of the groove and the size of the washer? If so, I could take these numbers to the local machine shop and get them to make me one.
Old Oct 24, 2004 | 05:40 PM
kp's Avatar
kp
it was the same diameter as the stock thin washer, it was around 1/8" thick. The protruding part that fit in the groove was just a little smaller then the slot where the tensioner is.
Old Oct 24, 2004 | 06:04 PM
LordFlux's Avatar
Thanks.
Old Oct 24, 2004 | 07:04 PM
Billiumss's Avatar
Thumbs up
I guess my tuning of your car is not that bad after all...
Glad I was there to see it...
Old Oct 24, 2004 | 10:16 PM
Nope, you did a helluva job, Bill
Many phone calls, late nights, and tech searching proved it's worth. Add this one to your resume.
Plus, it also helps the tuner and test car reside 1/2 mile from each other
Old Oct 24, 2004 | 10:41 PM
WS-Sick's Avatar
Nice looking Formula you have there.
Old Oct 24, 2004 | 11:11 PM
2FAST4U's Avatar
Very Nice times! Just be happy it was only a washer not more! And get the belt problem fixed as that seems to be many peoples problem!!!
