ATi superdamper/ supercharger guys
Old Oct 25, 2004 | 11:14 PM
GrannySShifting's Avatar
Default ATi superdamper/ supercharger guys
Anyone running the ATI damper what size belt are you running for the main serpentine and AC?
I doubt this ATI is any different than any other ATI even though it came in the blower kit, the blower pulley just piggy backs on top the ATI anyway
Old Oct 26, 2004 | 01:18 AM
1dirtyZ's Avatar
i had to get a serpentine belt that is 1 inch shorter ( if i remeber correctly) when i put the ATI damper on. the a/c belt remained the same.
Old Oct 26, 2004 | 08:46 AM
Parker TX's Avatar
what are the advantages to running a super damper on a supercharger/turbo set up. Is there any need for it if your just running your alternator with the crank pulley?
Old Oct 26, 2004 | 09:18 AM
A damper is supposed to help quell vibration in the crank to prevent as much crankshaft deflection/bending as possible. I dont know if the ones people run are always doing what they need to be, because from what I know on the subject (not that much ) they almost need to be tweaked for a particular combination. Different rotating mass weights, target rpsm etc should change the frequency and rpm where vibrations might occur
Old Oct 26, 2004 | 10:27 AM
1dirtyZ's Avatar
the other advantage is that you can "bolt" the crank pulley ( that drives the blower) to the damper instead of using dowels on the stock damper. ( trust me it works! and the peace of mind it provides is amazing )
Old Oct 26, 2004 | 10:44 AM
Parker TX's Avatar
What im asking, is it worth it, I took off my supercharger and went to a drag set up so all my crank is running is my alternator.
Old Oct 26, 2004 | 12:01 PM
ls1290's Avatar
Dumb Ass Vette Moderator
The ATI damper hub is keyed rather than pinned. A key is much stronger than a pin
Keith
Old Oct 26, 2004 | 12:02 PM
Parker TX's Avatar
I had mine keyed when i put the supercharger on.
