Any STS track times?
Old Oct 26, 2004 | 08:47 PM
Drew778's Avatar
Default Any STS turbo track times?
I'm just wondering how the lang is being so far back.
Thanks
Andrew
Old Oct 28, 2004 | 01:18 AM
Drew778's Avatar
So the kit is good if you just want dyno #'s
Old Oct 28, 2004 | 03:08 AM
dasorrells's Avatar
Default Track Times
I have a 2000 Camaro LS1, underdrive pulley's and an STS rear mounted turbo kit at 5psi. I went to the track for the first time this past weekend and I wasn't too upset with the results. My first run was at 2:00 with high humidity in the heat of the day and my 1/4 was 12.75 at 112.5mph. My 60 ft time sucks, because I have no stall (2.1-2.25). My best run was 12.63 at 113, and my worst run was 12.94 at 11.42. I did about 10 runs. I am about to get 38 lb fuel injectors, and customize a front mounted intercooler so I can run 7 or 8 psi. I also plan to get a 2500 stall in the near future. I am open to suggestions if anyone has some good ideas.
David
Old Oct 28, 2004 | 03:32 AM
Drew778's Avatar
Do you have you 1/8 time and mph and was is pretty easy to tune?
Thanks
Old Oct 28, 2004 | 10:13 AM
F8L Z71's Avatar
12 Second Truck Club
I went from 16.2@86mph 2.4 60' to 12.62@106.5mph 1.81 60'
with:
STS kit at 12psi with intercooler
gutted cats,
226/220 turbo cam
TT3000 stall
and about 300lbs weight removal.
Old Oct 28, 2004 | 10:26 AM
JERRY2500's Avatar
14 Second Truck Club
Times in sig. My 60' sucks because of traction problems.
Old Oct 28, 2004 | 10:38 AM
SSnakekiller's Avatar
Unhook the trailer and you will launch much better
Old Oct 28, 2004 | 10:52 AM
JERRY2500's Avatar
Thats how i get traction.
Old Oct 29, 2004 | 12:02 AM
dasorrells's Avatar
Thanks
My 1/8 miles were not very good due to my high 60 ft times. I consistantly was in the 8.30s at 88.xx mph. As for the tune, i spent $400 at a ls1 specialty shop called racetech and let them tune it.
